Not sure if the chassis helps with dissipation for the PSU. If so, a coating or cover would impede that.I see neoprene not so insulating, guess this
https://plastidip.com/our-products/liquid-tape/
would be better
would be better
Yes even 12 volts can cause a very nasty shock. For example leaving your sweaty body across the large chrome bumper and grabbing a socket wrench and putting it against the battery terminal. Oh yes this is the voice of experience. Now and you multiply that voltage by 4 to 48 volts you just multiplied the current that would run through your body by 16. Very dangerous indeed, these can be lethal shocks. The big concern is to isolate all chassis surfaces. Remember the chassis of all your marine electronics will always be at the negative ground potential. If you can touch both chassis without isolation you get zapped.Thanks, that is exactly my concern. At high currents I bet 48V could cause a health issue in the wrong circumstances, especially at such high current rates.
I could enclose the case in neoprene, put huge safety-orange Shock Danger stickers?
That is, if there is any downside to my isolating the rectifiers from the outer chassis.
Is there?
This will not be "installed" as such, but mounted in an airtight Pelican style case, only opened while charging maybe an hour or two.Is it all built to marine standards?
Each internal module is designed with powerful active fan cooling, designed to be inserted into OEM rack server cases etc.Not sure if the chassis helps with dissipation for the PSU. If so, a coating or cover would impede that.
Before cellular I had a mobile phone company. We had telco (-48V) interfaced with radio transmitters (+12 and 24V). I can tell you we had to take great pains to keep the 2 systems isolated. Also the telco rack frames were referenced to the radio system grounds. The telco "grounds" were different from the actual site grounds. Short answer is this will be a really complex undertaking.
Wow, thanks much to both of you for your replies!I'm a power tech for a telcom.
I handle the 48 volt buss bars all the time, the only time I ever get shocked is when I'm sweaty and I'm leaning on something grounded, BTW almost everything is grounded in a telephone office.
I don't know if the connection between the chassis and rectifiers is to their AC input or DC output side "ground". Seems from others' statements the latter is more likely?I would assume that the equipment case is connected to the supply ground.
It sounds like this is thought out so far. Just keep your diligence for safety, reliability and maintainability.This will not be "installed" as such, but mounted in an airtight Pelican style case, only opened while charging maybe an hour or two.
But mfg states designed for remote telecom station usage.
All wiring infrastructure will be to high standards, marine / milspec.
OK based on that, I will look at other options for getting the DC output I need from genset / shore power.A boat is no place to try and mix a positive and a negative grounded system.
I see that means Fire Alarm Control Panel systems, and I've read a little on GFCI, RCD and RCCBRCCB devices.FACP systems have sent DC control/operating voltages in the midst of other AC and RF since before we were born.
