Infinitely adjustable genoa tracks
letlmt
Oct 21, 2018
151
Catalina Capri 22 Lake George
On an old boat of mine I had adjust genoa tracks that were controlled by a line instead of the pins and holes like on the Capri 22.
I could adjust the lead car while under load to get the sail shape just right.
Have any of you done this?
Nov 26, 2012
1,654
C&C 40-2 Berkeley
Yes. I installed those on my boat. The main advantage is that you can adjust the car location while the sail is under load. This allows you to instantly see how it affects the boat.
Feb 16, 2017
164
259
Those are good ways, there is a system that is a lot less expensive see pic. This system the most adjustable as I can use barber hauler to the rail for reaching. Total cost was less than $200 for both sides and less than 2 lbs.
letlmt
Oct 21, 2018
151
I have seen something similar to this on an expensive race boat.
I cannot tell exactly how it works but it looks like the sheet goes through a block that you control up and down and in and out so that you control the clew height and distance from centerline, effectively the same as moving the car forward and backwards. Right?
Aug 1, 2011
3,972
The Garhauer EZGlide is a fantastic system. While it may be a little overkill for a 22, the operation of the system is what it's all about.
Feb 16, 2017
164
259
Well yes, I can go side to side and up(car back) and down (car forward). It is a 2:1 from the car to the lead and a 3:1 for the purchase. I should have used 2:1 instead. you can just barely see the front purchase block in this pic below.
3,972
It's regular 1" track. Not Harken track, that's a different size.
Feb 16, 2017
164
259
Well the problem is the width of the recess in the deck. Harken will not fit in the recess, the car are if memory serves me well, .135 to wide to in the recess. This due to the required room with the car for the recirculating balls in the car.
Slartibartfass
Capri 22 Mod
Dec 13, 2015
499
Catalina Capri 22 1139 Mamaroneck, NY
The 1" version of the Garhauer works. Got it today and did a test fit on the Genoa track....
Slartibartfass
Capri 22 Mod
Dec 13, 2015
499
Btw the sliding part does no longer have ball bearings but low friction padding contrary to what's out there on the inter web...... must have been a design change after (I assume) too many folks lost the (their) bearing during install...
