Peak Sierra pet-safe antifreeze.
Mar 26, 2011
4,015
Corsair F-24 MK I Deale, MD
LD50 = lethal dose 50% using a specific protocol.
That was not an attempt to relay "truth;" toxicity is much more complex than that, far too complex for a forum. For starters, acute human toxicy generally has to be estimated, due to a shortage of volunteers. I only intended to relate the order of magnitude. Yes, ppm is a misnomer, since it is mg/kg body mass, but that too is sort of a fine point.
So according to that "test", salt is the most toxic substance of the bunch?
You should read an MSDS sheet on Hydrogen Hydroxide. Scary stuff! Here is an excerpt...
CARCINOGENIC EFFECTS: Not available.
MUTAGENIC EFFECTS: Not available.
TERATOGENIC EFFECTS: Not available.
DEVELOPMENTAL TOXICITY: Not available.
You should avoid Hydrogen Hydroxide at all cost. We just don't know what this stuff might do to you.:shhh:
Whatever floats your boat. :biggrin:
Personally I'm more worried about dihydrogen monoxide. http://dhmo.org
Likes: rgranger
Gunni
Mar 16, 2010
5,937
Have you not been paying attention to your doctor’s nutritional advice! :biggrin: But this is why toxicology is only partially a numbers game - long before you could choke down a lethal 7 ounces of salt you could easily wash it down with enough ethylene glycol-tainted coolade to kill you in a long and lingering way. And who really wants to survive only to be on the kidney transplant list?
