Can you use your hot water heater to heat your boat?
Dec 4, 2017
79
Hunter 466 Seattle
I have a hydronic system with a diesel powered Webasto furnace. It heats up the hot water to scalding hot and the boat gets really toasty. I'm a liveaboard in the PNW and coming up on colder months so I'm just wondering about the feasibility of using my electric hot water heater instead of the diesel furnace. Has anybody tried this? I think I could probably hook up the circulation pump to work manually or even via thermostat. I'd love to hear what you all think. It might even be cheaper than diesel (and far more convenient than hauling diesel down the dock all the time.)
Apr 7, 2016
184
Sailboat 35 Sailboat Anchorage
I have a heater that works off the engine. I’ll get you a pic this weekend. This’ll be my first winter with it so I don’t know how well it works.
Hunter 34 Alameda CA
I asked this question a couple of years ago. Basicly, we have a 1200 Watt heat source while hooked up to shore power. I thought about a circulation system of the hot water through a heater core or radiator with a small fan behind it. This could blow warm air into the boat and a thermostat would cycle the circulation pump on and off. I've seen bits and pieces on Amazon but haven't tried to cobble anything together. There are systems like that for big rig trucks but expensive.
Feb 20, 2011
8,062
I'm not sure your water heater can put out as much heat as efficiently as the diesel, but if your electric bill is a constant, it may take the edge off of cold mornings.
Likes: VisionPNW
Nov 6, 2006
10,248
Yes you can, but the water heater would limit your heat output a lot compared to diesel.. The heater (assuming a normal 6 gallon 120volt heater) can't generate more than three or four thousand BTU .. even the smallest Webasto is 2-4 times better at making heat..
Likes: SG and Gunni
Dec 4, 2017
79
Hunter 466 Seattle
Allan, since I already have the hydronic system, I have the radiators and fans plumbed in and ready to go. I would just need to modify the circulation pump to circulate coolant through the system when the diesel furnace isn't running.
Dec 4, 2017
79
Hunter 466 Seattle
The heater can't generate more than three or four thousand BTU
Thanks for putting this in persepctive. I didn't think about it in terms of heat output capability. I think it would be less efficient than a regular 1500W heater and far more complex.
Beneteau 323 Annapolis MD
being a smart ass- why would you need to heat HOT water??. Most heat cold water to MAKE it hot. I'll go to my room now :)
There's always a smart-ass n the room. Actually, if the water in the heater tank is, say 119, the thermostat will heat it to it's 120-140 rating. So, the water heater is, indeed, heating hot water. Now, will you please go to your room?
357
Hunter 33.5 Tacoma, WA
But you're electric bill will no longer be constant. It will be MUCH higher now that you're circulating hot water around your boat (which cools it), and force the hot water tank elements to stay on much longer.
Apr 7, 2016
184
The heater I posted above is off your engine and not water heater. I should work great when the engine is running. But I doubt it will be any cheaper to operate than your furnace.
Is there a thermostat on the heater to control the water temperature? Household boilers always have a high limit thermostat to prevent over heating. If so, turn the high limit thermostat down.
Feb 20, 2011
8,062
Some places, such as the docks where I'm at, charge a flat fee for electrical service. No meter at the slip.
I pay a certain amount whether juice gets used or abused. YMMV ;)
Likes: mz4wheeler
Dec 29, 2008
806
Treworgy 65' LOA Custom Steel Pilothouse Staysail Ketch St. Croix, Virgin Islands
Our Webesto diesel heater would be similar. And, our hot water heater has lines coming from the engine cooling system which flows through a heat exchange in the water heater. If you had a similar arrangement, you could tap into those lines to your diesel heater lines, and circulate through the hot water heater. Our systems poth have coolant running through them. I'n guessing yours does, too, with antifreeze in the mix. I don't see why you couldn't do it, assuming your water heater has a heat exchanger for using engine coolant already. Otherwise, I don't think you would want to run actual drinking water through your hydronic system. I assume it has to have antifreeze in it already which, of course, you wouldn't want mixed with your hot water in your water heater.
Dec 29, 2008
806
We've also contemplated getting a 12V heating element for our hot water heater to use as a dump load for our solar panels, replacing the 110V heating element. We would be more likely to have hot water at any given time with that arrangement. If you could have dual heating elements, you could have both, if you had solar, and heat the water with solar during the day, and only draw shore power at night.
Just curious - I'm sure it varies by what the temp is outside and what you set the thermostat to for your diesel system, but what is the fuel usage rate per hour or per 24 hour period? Inquiring minds want to know...
Dec 29, 2008
806
:poke:
OMG just buy a heater and plug it in./
An electric heater will only blow warm air into one area of the boat. I'm sure his diesel heater distributes the heat throughout the boat. I know that all 4 cabins in our boat are heated (with individual thermostats in each space, I might add)
by the diesel system. Not that we have EVER used it - though, when it gets below 80 here we tend to put on long pants and shirts, and use a blanket.:poke:
