So I did a fit up in my back yard. Kind of had to make some educated guesses and learn as I go.
Jib set up, what order is it done in and how tight should it be wound? So I put the line in the roller foiler base, but how tight does the sail have to be? Should I wind the rope 1 turn around before going through the hole? Is there a quick trick to getting the rope through the hole?
Did I do the clew line right? Does someone have picts of the boom setup to sail and setup on the reef?
Why is it they manufacturer does not seem to have a detailed setup of the lines and such?????? What about the boom do I just leave it down while setting up? What seems to work the best. Then there is the whole how do you fold the sail and so one. The simple stuff I have no clue, but I am trying to guess.
What is the best thing to clean up the mast? It is dirty. What do I do to lube the slot where the sail rides as it was kind of catching as it went up.
The main sheet line I have does not have a preformed eye on the end to attach to the pulley. Is there a preferred knot to use?
The bracket on the mast that holds the spreader bars has some loose rivets. The stainless also is slightly beat up. Easy for me to fix, but should I redo the rivets and make it tight or are they just normally a bit loose?
The pulley's at the top of the mast have some cracking and are chalky. Is this a problem or dont worry?
The rubbers on the top of the keel are going bad.
Is there a recommended bungie used to keep the keel out in case you go over? Am I supposed to have one?
Found a crack on the hull bottom in the middle of the transom. I will do a repair to it before it sees water. Should I flip the hull upside down so the epoxy stays in place? Or just tape over it?
Found some cracks along the area where the grey rub rail is. How hard is it to take the grey rub rail and how do I do it?
There are 2 pulleys on the front face of the mast near the top. What would they be for? I am pretty sure that one could have a non roller jib if you wanted, but what about the second one?
It people could post picts of how they run lines and such please do. I realize to some extent is it perference as to how you run them. Please let me know about this stuff.
For the various pins like those that hole the shroudlines and such. Where should they be done with cotter pins and where should I use those ring clips?
Thanks,
Kevin
Thanks,
Kevin
