Winterizing the sanitation system: Step 1. Pump out and THOROUGHLY rinse out the holding tank and any overboard discharge pump and its related plumbing. Step 2. Just pouring antifreeze down the toilet into the tank will NOT winterize a sea water toilet, just the tank. So unless you have a toilet designed to use pressurized fresh water, disconnect the flush water intake line from the thru-hull (close the seacock first!) and stick it into the jug of antifreeze...pump the whole jug through the toilet into the tank. If your toilet intake is teed into the sink drain line, it's even easier: just close the sink drain thru-hull and pour the antifreeze down the sink...flush it through the system and into the tank.
If your toilet is one designed to use fresh water, winterizing the fresh water system winterizes the toilet, the tank is the only thing that needs antifreeze, so you can just pour it into the bowl and flush it into the tank.
The owners manuals for the LectraSan, ElectroScan and PuraSan includes complete winterizing instructions and it's very important to follow them if you don't want to damage the device.
--Peggie
