O'Day 322 replacement sliding hatch
Jun 1, 2007
272
O'Day 322 Mt.Sinai
Has anyone replaced their sliding hatch on a 322 or similar boat (the horizontal sliding hatch, not the vertical hatch/pem boards).
My lexan hatch is cracked since I bought the boat, and I really need to replace it. I'm concerned that if I find a direct replacement, it'll cost me an arm and a leg. So, I'm also considering making one from wood and adding lexan inserts to let daylight in.
Has anyone done this kind of thing?
Nov 6, 2006
10,120
I just replaced my old original. It was 1/2” plexiglass, so I replaced it with the same. Carefully measured then some finishing. All is good
Jan 2, 2017
765
O'Day & Islander 322 & 37 Scottsdale, AZ & Owls Head, ME
D&R Marine will sell you one for $750. Just talk to Rudy.
If you make one yourself, be sure to make it strong enough to stand on.
Jun 1, 2007
272
O'Day 322 Mt.Sinai
Did you add a bend to it? The original bends slightly up in the middle, I guess for strength?
Jun 1, 2007
272
O'Day 322 Mt.Sinai
Yea, sure I'll talk to Rudy, but I'm hoping to come in less than $750 if I can..
Jan 2, 2017
765
You can probably get a local plexiglass shop to make you one for less but it’ll be hard to get the curve right. Best to take the old one to them.
Jan 2, 2017
765
The bend in the plexi matches the curve of the cabin top. A replacement would have to have the same curve or it won’t slide.
Nov 6, 2006
10,120
Fortunately, mine is flat.. no bending needed.. The bending thing makes it a non-trivial job !
Mar 20, 2016
595
Beneteau 351 WYC Whitby
Use plexiglass( acrylic) not lexan(polycarbonate) lexan scratches easy, boat makers use acrylic. If you have a big enough oven put the sheet in with a piece of wood 2x2 in the middle. Heat between 275 to 350 degrees it will become soft and bend stay closer to 275 too hot and you will get bubbles
Jan 2, 2017
765
You’d need a really big oven to handle that slider.
Jan 7, 2011
5,746
Oday 322 East Chicago, IN
A previous owner had replaced the slider on my O’Day 322 with a fiberglass or expoxy-covered hatch.
I really like it. If you look carefully, you can see it in this photo.
It has some arch to it, so rain runs off. It is robust enough for me to stand on.
Likes: Mickstr
Jun 1, 2007
272
O'Day 322 Mt.Sinai
Thanks Greg. That looks like another winter project for me!
Jan 7, 2011
5,746
@Mickstr,
Here are a few photos of the replacement hatch slider on my O’Day 322.
I also have the washboards, which can replace the doors, but I like the doors better.
I didn't do the replacement, so don’t have a lot of information.
E9CD6E61-09B7-4203-964C-7B266BABE1F3.jpeg 24E9BC92-8BBA-439A-9FF2-A2FB72AC0115.jpeg DB41BC0C-6EE5-4431-9087-E04EB6EE54B5.jpeg
Likes: AlastairLC
Jun 1, 2007
272
O'Day 322 Mt.Sinai
@Mickstr,
View attachment 155194 View attachment 155195 View attachment 155196
Thanks Greg. Just for grins I'm going to get prices from local acrylic companies, as I do like the light that affords. But, if it's too costly, I may do what your PO did.
Dec 28, 2015
39
O'DAY 322 Bridgeport CT
I have repaired the hatch boards on my 322 using west style epoxy with very careful cleaning and clamping of the pieces.
Also there is a very good Plastics Company in CT called Moderm Plastics. They may be willing to supply material or even make a replacement. They bend and machine acrylic and lexan sheet.
Jun 1, 2007
272
O'Day 322 Mt.Sinai
FYI, I'm getting one from Rudy for closer to 600. Just have to wait a spell for it to be fabricated in CA.
