- Oct 22, 2014
- 24,516
AIS and VHF signals are very close in wavelength.
Vespers idea:
Pre-sales or other questions: info@vespermarine.com
New Zealand Headquarters
Vesper Marine Ltd.
45 Sale Street, Freemans Bay
Auckland, New Zealand
Phone: +64 9 950 4848
United States Sales and Service
Vesper Marine, Inc.
128 Bartlett Ave
West Creek, NJ 08092
Phone: +1 609 246-5067
Vespers idea:
Finally an antenna designed for both VHF and AIS!
This antenna is specially designed by Vesper Marine to be used with our Antenna Splitter. Up until now you've had to choose an AIS-tuned antenna that is optimized for the AIS frequencies but has lower performance for your VHF radio. Or you could choose an antenna that is designed for VHF radio communications but isn't optimal for AIS. Either of those works but we've got a better solution.
We've created an antenna that solves this dilemma. It has two key features that combine to make it ideal for use with our antenna splitter:
@Bob S I have no experience connecting the Vesper and Garmin products. Vesper is NMEA 2000 compliant. It would depend on Garmin. You should post the question on the Vesper website. They are great at getting back to you. I believe there is now a Vesper distributor in NJ. You might give them a shout. This antenna is specially designed by Vesper Marine to be used with our Antenna Splitter. Up until now you've had to choose an AIS-tuned antenna that is optimized for the AIS frequencies but has lower performance for your VHF radio. Or you could choose an antenna that is designed for VHF radio communications but isn't optimal for AIS. Either of those works but we've got a better solution.
- Wide bandwidth of 6 MHz means it will cover 3 MHz above and below the center point
- 159 MHz center frequency gives excellent performance for VHF radio (156 Mhz) and AIS (162 MHz)
Vesper Marine Ltd.
Vesper Marine, Inc.
128 Bartlett Ave
