Picked up a good used roller curled last yeat. Fella even sent spare cones. Explicitly stated that the fittings were for 7mm.
Published state for my forestay are 9/32" , which according to multiple sources and my calculator are 6 .7mm. Actual mic size of said wire is nearer to 6.5mm. I
Is swage-finish wire typically undersize vs original diameter? Is 15 to 20 thousandth light i n dia. going to be a problem?
I would assume (engineering use!) that the cone/socket mechanism would take up this small amount of slack? What say you experienced folks?
TIA, Paul
BTW.... I hate spell changer!
TIA, Paul
