We have a 2003 Mercury 15hp outboard motor on our dinghy (which we purchased with our Beneteau sailboat) and it shuts down (or off) when under a heavy load.
He had a mechanic rebuild/service the carburetor ($300) and still have the same problem.
Since then he has tried:
-Changing the fuel tank and hoses (helped it to work for a while and then went back to the same problem)
-Changed the fuel in the tank
-Changed the gaskets and fuel filter
-Changed the spark plugs.
He removed the cowl and ran the motor with no load, it was fine but when he engaged the transmission to full throttle, it bogs down.
Does anyone have any helpful suggestions so that he doesn't end up throwing it in the canal? My sunny side can only get us so far!
Please send help! (Or a new motor if you have one!)
Thanks
Cara
Thanks
Cara
