Can anyone tell me how to correctly rig the lazy jacks? As I am not the original owner, I don't know if the sail cover is from Hunter? The system has a fixed cable with eye that extends from the spreaders, attached about 18" from the mast. The movable lines are then attached thru this eye, and then thru another eye on another movable line. There is also a block on the boom, along with a cleat near the mast. Right now I am not using the block or cleat. When I want to slacken the sail cover, I have to loosen the knot tied to the sail covers straps. I am sure the block and cleat are there for a reason, but haven't fully figured out how to properly rig?
