Last winter I connected with a Floridian Gentleman that was scrapping/parting out his 1978 H30 due to storm damage. Actually the connection was initially made on this forum. He insisted that the pedestal system he had was Edson. I assumed mine was too, because our boats looked identical. When the components arrived I cleaned and painted the bracket and polished the guard tubing, drilled and retapped the tubing base anchor set screws. Two weeks ago I installed the bracket and guard (easy peasy) above the control lever housing with only needing to make a slight bend in the speed control lever so it wouldn’t hit the guard support bracket. The original setup looked like this during dismantle.
After the images provided in previous contributions from you and
@Roland5048 commentary I now know my pedestal is a YS. I believe the round pedestal base may be the best clue. Regardless, I also believe that Edson and YS are interchangeable with respect to the guard and bracket. Perhaps the Floridian was also mistaken. Our completed project looks like this.
If you need dimensions, please let me know. I’ll be at the boat this next Sunday.
