ELCI, galvanic isolator and dinghy davits. The davits are SST so I’m not sure how they would effect the compass.
None of those should
significantly affect the flux compass.
1) The ELCI does have "coil"
2) Galvanic Isolator is possible, if you have the
Isolation Transformer type like
@capta [normally just simple diodes]
3) Dinghy davits for a Stern type Davit, if one Davit is much closer to the Flux Compass[FC], it should only
slightly offset the compass.
Mine is offset from my Richie Steering Compass [SC] by 5 feet to the Port side and about 5 feet down. It is
not on the Center of gravity of the boat.
Here is a way to possibly detect the problem.
Get a
simple magnetic hand held compass [HH]
https://www.walmart.com/ip/Magellan...mpass-Nautical-Decoration-Brand-New/118573476
or
https://www.walmart.com/ip/Lot-of-2...my-Camping-Hiking-Survival-Handheld/540661277
Put it by your FC. Does it point like the SC?
1) Move the HH toward your closest Davit
2) the Galvanic Isolator
3) the ELCI
Lets say it is affected by a
Davit...
You can
OFFSET your FC to match your SC by the FC calibration procedure. The FC will for all
practical purposes, match your SC.
We don't steer by 280.3456 Degrees but ≈280°
The Davit will be in a FIXED position.
BTW my FC was -10° offset. I calibrated my FC so the FC matches my SC good enough.
Lets say I set my Autopilot to 240° [
Magnetic and not True] but the real SC is 242°, you would still not be off course significantly in 50 miles.
Plus you GPS can be used to correct slight AutoPilot errors too.
All magnetic compasses are affected by MASS, not just metal. Metals are HIGH mass in a small package.
The Admiral stowed 3 cases of Aluminum canned beer next to our FC.
The Beer caused the offset.
We moved the beer to the opposite boat side and the calibrated FC,
offset went away.
Calibration and offset from my SC was a simple procedure.
Jim...
