Can rails be extended around stern? (H23)
P100D
Jul 24, 2016
129
Hunter 23 Nashville TN Percy Priest lake
I re-sealed my uprights. It is pretty easy to get to the washers and nuts. Looks thinner than it actually is. But being a diesel mechanic by trade I'm use to that. Just a screw would be insufficient.
Apr 27, 2010
1,279
Hunter 23 Lake Wallenpaupack
I agree you need bolts with backing plates or nuts. Getting under the deck to the starboard side next to the cockpit is problematic - you have to lay down in the lazarette area and sort of curve around. But it is possible; definitely a 2 person job. You do have some access to the stern via the access port under the gas tank area cover.
Likes: Ohiosailin
Nov 11, 2017
11
Hunter 23 Alum Creek Sailing Assn
P100... thanks so much; this is so close to precisely what I've envisioned.
And CrazyDave; you're spot on with the backing plate/washers being essential for this.
NOW to research a good fabricator for the offseason in my area.
THANKS to ALL :clap:
Likes: P100D
DJN51
Oct 26, 2009
377
Hunter 23.5 East Chicago In
Made these for my 23.5.Got everything from wholesale marine,practiced on 3/4 conduit.mainly hated where life line attached at stern,bad trip point.find good electrician he can bend it.One tip put pool sand in pipe eliminates kinks
11
Nice job DJN51. I knew this could be done, and envisioned it in a cupl configurations.
How is lateral support on yours, seeing that there's just 2 stanchions, and fairly inline front/rear?
Nov 8, 2010
11,386
If you can get triangulated corners in the back, then you can run a lifeline on a hook across the transom between the corners. Very secure, and easy to open for swimming. And the grill can still mount.
Nov 11, 2017
11
Yes, i can see how that triangulation would be fairly stout :waycool:
As an aside; what's with dual rudders? What model is this? (Yeah, she's cute)!
Nov 8, 2010
11,386
The triangulation allows the pulpits to withstand a full load against the rear lifeline without collapsing. If you just have a two-posted pulpit, it will pull them in and collapse.
The dual rudders allow for a wide transomed boat (The First 260 is 9 feet across the back) to heel and keep a blade in the water. Indeed at a big angle, the outward canted leeward rudder is standing straight up and down in the water and has a great bite. We never wipe out!
Likes: Ohiosailin
pateco
Aug 12, 2014
2,207
So something like this with corner posts would be stabler
Likes: Ohiosailin
DJN51
Oct 26, 2009
377
actually added another stanchion 6 in in front of cleat makes it a lot stronger.as my Lifering mounts there Advice put all fittings on pipe before bending or never get them on after!!!
Likes: Ohiosailin
Nov 11, 2017
11
Exactly right! Added stanchions added as per your photo would not inhibit any access I could fathom.
Again gentlemen; my thanks to all.
Likes: pateco
