Glow Plug Heater Circuit Issue M18 Diesel
Feb 9, 2011
70
Catalina 27 Forked River NJ
I have been chasing my tail with this Glow Plug Heater issue, and I could use some ideas.
Problem is: If I depress the GLOW PLUG Heater switch, I get no current or voltage to the Glow Plugs. If I apply power directly to the switch and depress it, or apply power directly to the Glow Plugs they draw current and heat up. (See attached PDF)
Glow plug resistance in parallel to ground (with lead wire disconnected) is about 0.7 Ohms.
The current flow to the Glow Plugs is about 17-18 AMPS . (Amp reading with a Fluke)
I am wondering if the Teleflex amp meter in the panel may be going bad. I measured the resistance across "A" and "B" and read 2400 ohms. The 12VDC power was off, but the existing wires were still connected, so I am not sure how valid that reading is.
However doing the math, the voltage drop across a 2400 ohm resistor with 17 amps would be quite high.
I am aware of the Wiring Harness/Trailer Plug/Battery Charging circuit mods and they are currently in the works.
80
Westsail 28 72 Long Beach , California
My friend had this problem with his C320 . When we were looking at it we determined there was power to the switch but no power at the glow plugs . He bought a new switch still no power to plugs , at that point I said just call the guy . Problem turned out to be simple the wires going to the engine were connected to a terminal block and then went to the engine . The mechanic put on a new block , clipped back the wires to new , wired it all back up and it was fixed .
Feb 9, 2011
70
I think I eliminated the wiring by going directly to both sides of the ammeter, one side worked the other did not, but I do appreciate the feedback and may cut back the wire going to "A" put on a new lug and see what happens.
Jun 24, 2014
80
That sounds good Mr. End , my friend discovered that if you blow hot air from a hair dryer into the air filter the engine starts right up .
Your problem IS the ammeter in the cockpit, regardless of whether it is working or not.
Replace the ammeter in the cockpit with a voltmeter. Install a glow plug solenoid.
Ammeters & Shunts 101: http://c34.org/bbs/index.php/topic,6032.0.html
http://c34.org/wikiwp/?rdp_we_resource=http://c34.org/wiki/index.php?title=Faster,_More_Efficient_Glow_Plug_Heating_with_a_Solenoid
http://c34.org/wikiwp/?rdp_we_resource=http://c34.org/wiki/index.php?title=Engine_Harness_Upgrade
May 20, 2016
3,015
You glowplug amps are down but if you haven’t done ampmeter, glowplug relay or the trailer plugs it may be ok. Your glowplugs should draw 12A each plug.
Als read about the alternator mount upgrade. It’s on Stu’sC34 site and on Marinehowto.com. If you have the old style and don’t want to repower in the next few years - move that onto the todo list just below trailer plugs and Ampmeter.
I did trailer plugs and alternator mount last winter, trailer plug mod took ~3hours
The alternator took 2-3 weekends as I had to wait for manifold gaskets, and fix some previously broken bolts. Pulling the exhaust off the back of the manifold was the worst part of the job and that wasn’t bad. Be sure and seal the studs to block threads (I use permitex #2 ) as they are “wet” and could leak.
Les
Jun 6, 2006
6,990
If you apply power to the glow plug switch it works!!!! so why is the switch not getting power? Assuming you have an off-run-start and not a preheat-off-run-start ignition switch.
the glow plug switch should not be hot all the time. it should only be hot when the ignition is in the run position. I've seen them wires several different ways. In all cases you have to have power to the switch so figure out why it is not getting power. Take off the glow plug hot terminal and stick a volt meter + prob in the wire. ground the other probe. There should be 12 volts if it is hot all the time,
OR
0 volts (start, and off) or 12 volts (run or preheat) if it is connected to the ignition switch
jviss
Feb 5, 2004
7,090
Tartan 3800 20 Westport, MA
Not connected to the ignition switch. Look at the attached drawing.
The drawing is great. Could you please reduce the ambiguity a bit by telling when you say
which terminal of the switch are you talking about? I assume it's the leftmost one - let's call it terminal #1.
There is one node you don't mention in the drawing which is node 9, which is the +12V rail, connecting the ignition switch "A" terminal, alternator field, Ammeter, tach, and temp gauge lights, oil light, starter switch, glow switch ,and fuel pump.
Based on your report, I suspect a bad connection from that node to terminal #1 of the glow switch.
When the key is in "run," is there 12V at terminal #1?
Feb 9, 2011
70
As stared on the bottom of the drawing, every this else works normally.
Power is available at the glow plug switch.
jviss
Feb 5, 2004
7,090
O.K., gotcha. It certainly seems you are dropping all of your voltage across the Ammeter when you depress the glow switch; except you didn't note the voltage at "A" when the switch is depressed. It could be a bad connection at the 30A fuse, or in the wire somewhere, but it's most likely the Ammeter.
When you measure the resistance of the Ammeter, was it completely disconnected from the circuit? These should read nearly 0 Ω when good, and usually fail open (∞ Ω). You might be measuring the DC resistance of part of the stator in the alternator.
Why don't you remove the wires from the Ammeter and measure the resistance with nothing else connected except your Ohmmeter.
For now, for operation, you can just move the "A" wire to the "B" terminal and ignore the Ammeter.
May 20, 2016
3,015
All this trouble shooting is wasted time. 1st make the mods @Stu Jackson recommended, and your problem has a 90% chance of being fixed. Your boat will be safer and more reliable. Don’t buy the CD kit, just buy a terminal block and ring connectors for the engine side - I like weatherpak connectors for the panel side. I used two 5 pin connectors and altered the sex so you can’t plug them in backwards. You can also group the wires as inputs on one connector and outputs on the other, that way power is on the female portion.
Les
Likes: brazenarticle
jviss
Feb 5, 2004
7,090
I beg your pardon. Troubleshooting is extremely valuable, not only in providing an understanding of why something is not working, but as a learning tool as well. Finally, this level of understanding will help if you have to make an emergency modification.
I agree with the recommendation of eliminating the Ammeter, maybe filling the hole with a Voltmeter; it perhaps does not go without saying that it is wired differently. I also agree with the recommendation of a terminal block for the engine side, and a glow plug solenoid.
May 20, 2016
3,015
You troubleshooting a system that should be replaced ASAP how is that not a waste of time. Your going to “learn” what 100’s of folks already know, it’s a horrid design prone to failing and starting fires.
Nov 13, 2013
723
Catalina 34 Tacoma
Your problem is most likely a connection issue. You just need to troubleshoot it or clean up all the connections. I don't see the point of the glow plug solenoid. I never needed one and don't need any clap trap on board.
His problem IS the ammeter.
Re the solenoid, I learned that when sailing on SF Bay when I needed the engine to start, I found that there is a HUGE difference between 30 seconds and 12 seconds. I don't think it's claptrap at all. It was ans remains a simple Ford solenoid, quietly sitting in the engine compartment doing its job when called upon. :)
But it's always:
Your boat, your choice. :)
The recommendations were based on 30 years of Catalina 34 experiences. I'm sure you're familiar with our trove of information.
Nov 13, 2013
723
Catalina 34 Tacoma
Stu: Love the information trove on the C34 site but I've found that when I sitting out on Commencement Bay my engine is usually warm enough from the trip out that I don't even need glow plugs. Zero seconds is much faster than 12. When at the dock and cold, I count 20 one thousands and usually starts on first try. I do concede that shorter and heavier wire runs are better than longer smaller runs but is it really worth the effort and additional failure points?
I agree that if the engine is warm then 0 seconds is a SURE winner!!! But I've found that after two or more hours I still need more than a warm engine and use the GPs.
Glad you enjoy the C34 site.
I simply don't think of it as more failure points, I think of it as a safety improvement because the whole GP electrical load, which is substantial, doesn't have to run up to the cockpit and back down to the engine in (TINY UNDERSIZED) #10 wire. My solenoid has been in since the late 90s and is still working fine. Probably because I do have a spare!:)
Nov 13, 2013
723
Catalina 34 Tacoma
It sounds like the OP doesn't have a start battery which could be part of the problem. That long wire run from the house bank and up to the cockpit may be part of the problem. Put in a start battery with short cables to the starter and you will substantially reduce voltage drop not just for the starter but for the glow plugs as well.
Feb 9, 2011
70
I wish I would have totally disconnected the wires from the ammeter and read the resistance. But even with the wires connected, I should have read less than 2400 Ohms. (least path of resistance) I do not ascribe to replace components just because others have. I need to first resolve the issue to my satisfaction and identify the real problem then make the correct fix.
In the interim I ran a new wire from my electrical panel through a spare switch directly to my glow plug. 10 seconds of juice to the plug and the engine happily starts. I WILL find the actual problem and get it corrected. just may take some more time in the lazarette.
Likes: jviss
