Marinco locking ring broke
Jul 5, 2011
772
Oday 28 Madison, CT
No sailing weekend is complete without breaking something, right? This time it was the black plastic threaded locking ring that secures the female connector to the boat connection. 30A Version. Just broke in half so I went to West and bought a new one. Of course no one there could tell me how the bloody thing fits onto the plug portion. Anyone with experience?
JamesG161
Feb 14, 2014
8,105
Hunter 430 Waveland, MS
Use the old one with plastic glue, since it is now "split ring".;)
Jim...
Jul 5, 2011
772
Oday 28 Madison, CT
Jim...
Not sure if you were joking, but that will not work. It is not split, but shattered in two larger a nd a couple smaller pieces, not all which can be located.
JamesG161
Feb 14, 2014
8,105
I was joking a bit. I found the rings to be useless and now love the new EEL clamp on type that "pinch and twist".
The marine "twist on" are ok and should not need more to provide seal.
Why do i say that?
The new EEL type don't weather proof it. Just provide a gentle "clamp on".
Jim...
Likes: Parsons
@odaydokay Perhaps this is the moment to upgrade your fitting and cord to a SmartPlug.
You can use the same wire, only change the boat fitting and swap out the female plug.
Once you go smart plug you'll never go back...
Rick D
Jun 14, 2008
7,206
Add a little soap when you are trying to get it over the raised part of the plug molding.
May 27, 2004
2,059
Yes Terry, it does. Sometimes the ring won't fit over the female end easily!
Jul 5, 2011
772
Oday 28 Madison, CT
Now I am confused, but it does make sense to start from the male end to get it on, threads facing female end and then slide it the 25' all the way to the female end where it resides. Correct???
That will work..
Dec 25, 2000
6,062
Correct???
Not necessary, but if that works for you...
When Marinco sent me a replacement ring, it came with install instructions. It slides right onto the female socket end, the end that plugs into the boat and locks with the ring. Easy peasy Japaneasy.
Jun 21, 2004
3,220
Beneteau 343 Slidell, LA
Second that recommendation!
One of the best upgrades that I have done. No more fiddling with aligning the female end of the plug and no more dealing with that plastic ring that always wants to cross thread or jam. Much superior conductance also. Highly recommended.!
772
Oday 28 Madison, CT
Tried this AM from the male end and that is no go, so will go to the female end as you suggest. Surprised that it will slide on one direction and then work the other direction to hold the collar on when screwed in, but I am sure if you got it to work it will work for me. Many thanks.
o
Dec 25, 2000
6,062
o
You're welcome. The socket (female end) tapered molded flange is designed to allow the ring to slide over it, but prevent it from coming off. Even with the old cord that we had, the replacement ring just slides right over the flange and into place. I suppose you can put some lubricate on the flange to help it slide on, but was not necessary in our case. Please let us know the outcome.
Dec 25, 2000
6,062
Our ring broke during a blow, which placed enough strain on the boat end to break the ring. When I later checked on the boat the socket was just hanging from the plug, still supplying juice to the boat. Not sure but I think the wharfinger was fiddling with my spring lines and moved the boat enough to place the strain on the cord.
I have since clamped a piece of three quarter inch nylon strap onto the cord with a carabiner on the other end clipped to a stanchion, as a strain reliever. The strap was once a dog leash that I found on the road during one of my jogs. Never know what you find might may come in handy some day. Yes, and wifey gives me a bad time, too.:solame:
Dec 25, 2000
6,062
