There are three active elements in good sound absorption materials: absorbing, mass layer, and dampening. Lead sheet is an excellent mass layer, as it is "dead," i.e., non-resonating. (According to my recent education on this.) The reflective material is to protect the sound material from excess heat.
Excellent explanation and clarity, at least for me. Thanks
@jviss
_______
I started looking at sound reduction
Me too!!
I went to Defender and looked up the 1" sound barrier stuff that seemed to be what
@Rich Stidger et al. were discussing. This is the linked material, I think.
https://www.defender.com/product.jsp?path=-1&id=3018150
So I took the...
Sound Reduction Challenge...
Here is the sound reduction Data by ASTM standards, which is the common reference to all Sound Reduction Material. Note: Personal Protection by maximum 80 dB volume in not the key here, but sound frequency reduction.
Here is the Defender Material Data..
https://www.defender.com/pdf/301872_DATA.pdf
At the bottom, is a table with
Sound Absorption Coefficients at octave band center frequencies, Hz.
Their label is "Sound Absorption per ASTM..."
A
Sound Absorption Coefficient of 1.0 = 100% of that Frequency absorbed and one of 0.14 = 14% absorbed.
The largest was 0.79 at 2k Hz.
Next is the Owens Corning Sound reduction Duct Board's data at 1" comparison thickness.
https://dcpd6wotaa0mb.cloudfront.ne...etR-Duct-Board-Data-Sheet.pdf?v=1476984225000
This significantly out preforms the Defender Material as a sound reducer.
Example 0.99=99% at 2kHz
The only frequencies of lower reduction were the 125 and 250 Hz, which are the low frequency "Humming"
_____
Ok like
@jssailem investigated, what was a Auto Diesel noise? That link discussed the MLV lead layer material.
So I looked up a full testing of sound by a Diesel Engine...
Gulp! What a study...
http://acta.fih.upt.ro/pdf/2014-3/ACTA-2014-3-21.pdf
You are welcome to gag on that, but here is MY take away...
The highest volume [dB] takes place a the ≈2k Hz frequency [based on Crank shaft position]
But the "Hummmm" is the 125, 250 Hz. which amounts to most of what I hear, but it is does
not drown out human speaking frequency.
_____
So if you want Volume control use the Duct board.
If you want very little "Hummm" reduction, with Sound Reducers they work about the same, only about 37% maximum for Defender Material vs Duct Board at 19%,
Don't gag to much on this.
As I said, I was curious.
Jim...
