Full disclosure my name is Jason. You may recall the name "Mike Honcho" from the movie Talladega Nights. I use it in forums
Going through Deception when running 7kts? With or against? More guts than me...I was apprehensive about going thru some of the “scary” passages despite going thru wires ones. As a kid - so went miles out of my way to avoid deception pass or La Conner. @jssailem cured me of that when we did a sail together and went thru deception when it was runnin 7+ kts. No problems. Same with La Conner and the “ditch” easy once you’ve done it or go thru with someone who has.
In your area around Tacoma the Narrows can move the water, but it’s really wide so no sweat. Agate pass mentioned above is narrower but just watch the current (DeepZoom.com or a current atlas). I’ve sat off point Wilson doing all I’ve 1.5 SOG for what seems like hours - but that is not common if watching the current.
Planning trips is more complicated. @jssailem uses Costal Explorer (Navigator??) from Rosepoint as you can set current locations for various legs of the trip. Most common nav apps ignore current
Les
Hi Bill, welcome to the PNW where the sailing season lasts but a week, gunk holing locations forget it and currents always running against you. Plus never any wind, always rains, never any sunshine, etc., etc., etc. That is the PNW narrative we use for newcomers.How long is the sailing season, are there a lot of gunkholing destinations, do th strong currents cause scheduling issues
That was a low tidal day. the lowest low I have seen in Oak Harbor was -4.2' and the highest high was over +13'.Bill. Here is an atypical anchorage off the south coast of Lopez Island. Depths are in fathoms.
And a tidal report for a nearby location.
It is said sailing in the waters of the Puget Sound makes sailors. You’ll get to exercise all your navigational skills.
As one who goes through Deception Pass several times on every cruise I almost never try to time the slack. It can and often is up to 45 minutes off due to wind influences. I time it to go in my direction which means I can go through 12 out of 24 hours whereas slack is only about 10 minutes long four times a day If you miss slack going to an adverse current you are stuck for 6 hours.Going through Deception when running 7kts? With or against? More guts than me...
Terry, as someone mentioned, AC is very east coast-centric. I looked at it back in SF and it was useless, unpopulated as it were. Before you bother with it on your phone, why not try it on your computer and see if there's anything worthwhile. I haven't since I've been here, since I've gotten more info from my new "real" friends here than anything I could get from AC. In fact, I haven't even looked, I trust them more! Good luck. Let us know what you find. I may even give it a go soon...Any other source besides Google?
I just did. What a waste. Not much of anything for comments that aren't better covered by Waggoners. At least in Canada.I may even give it a go soon...
Those don't look like Canadian Charts John. Stu now needs the depths in metres!"No Canadian Charts!' "
