Name you poision (knot)
Feb 17, 2006
5,274
Which knot is your go to knot when you want a stable, secure hold? Would it be the Bowline (on the left) or the Perfection [Angler's] (on the right)?
Be nice and don't berate someone who has a different opinion.
Dec 1, 1999
2,391
Hunter 28.5 Chesapeake Bay
I have a lot of "favorite" knots, but over many years of sailing, I have never had a properly tied bowline fail. Fast and easy to tie. It wins my vote.
Knots have uses... @JamesG161 I like that Running Bowline knot if I was tying it around something that could survive the squeeze, like a log or stick that I wanted a stable, secure hold.
I would not want that knot tied around me when I need a stable, secure hold then let you pull me into the boat. The knot would cut me in two.
Choice of design follows function.
JamesG161
Feb 14, 2014
8,105
Hunter 430 Waveland, MS
Not in your "Mummy" outfit.:laugh:
It goes up under the arm pits, just like a USCG retrieval sling, but it is not padded for you comfort, but rescue.
Jim.
1,609
Hunter 26.5 West Palm Beach
Jokes aside, the perfection knot is a good knot, as long as you don't need to tie it around something.
If the issue with the bowline is the tag end being inside the loop, then you can just tie it backwards, with the tag end on the outside. It holds just as well either way.
True.
Except: if you use it on a tight loop, like for your jib clews, it becomes difficult to untie it because the part that can move to loosen it is constrained back up into the loop, and can't slide down the standing end. Think about it, or try it. I always have to have the jib clew tucked under my arm and am facing away from the sail when I tie it or it ends up being done "backwards."
capta
Jun 4, 2009
5,100
I also have never had a bowline fail.
The advantage of a bowline over just about any other knot is it's ability to be untied, even after extreme tightening. We used a bowline on the 4" or 6" polypro tow lines and even after days/weeks of towing extremely heavy barges, we could always undo a bowline.
I actually have seen a bowline fail, but it was probably not properly tied. The tail pulled out as the knot rolled over. I also have seen bowlines pulled so tight they were impossible to get undone. I'm not a fan of the fisherman's hitch or the clove hitch because of that. I use the fisherman's bend (shown here with a different name) http://www.animatedknots.com/roundturn/index.php
a lot and a slippery double sheet bend when tying to a loop of rope.
I love the taught line hitch and it took me a while to figure out the difference from a rolling hitch.
- Will (Dragonfly)
Likes: JamesG161
danm1
Oct 5, 2013
233
Hunter 356 Mamaroneck, NY
I use a backwards bowline as my 'go to' knot. It works, you can untie it, and, most importantly, my hands know how to do it. I find that if I have to think about a knot, I don't use it.
... I always have to have the jib clew tucked under my arm and am facing away from the sail when I tie it or it ends up being done "backwards."
Yes. I don't tie it facing the sail. Years ago I had a practice line and tied like a thousand of them. I don't have to think about it since then but I like to start the same way. Since I want the tail to end up facing away from the shrouds I have to reverse the Starboard side. That' a challenge for the lexdysia inflicted.
Feb 17, 2006
5,274
Same here. If I tie a knot with the bitter end in my right hand, I cannot tie the same not if the bitter end is in my left hand. Go figure.
Aug 3, 2012
2,542
That is a good point. We should practice tying from more than one position. We cannot count on always being in the same position.
