View attachment 150663 I can't sheet the genny in very tight with the sheets going outside the shrouds and the placement of the jib fairlead results in a lot of chafe with the sheet dragging on the shroud. I'm thinking if I bring the sheets inside and don't unroll the genoa all the way so the leech doesn't quite touch the shroud I might be able to point better.
For downwind maybe I could use a snap shackle to attach a sheet running outside the shrouds.
