Should I lead my genoa sheets inside the shrouds?
Jun 14, 2010
307
Seafarer 29 Oologah, OK
I tried running the sheets inside and the consensus is right - loss of power from partially rolling the genoa more than offset the very modest gain in pointing ability. I found that I had to furl the genoa quite a bit more than I had thought. The leech rubbed the lower shrouds with any degree of overlap at all. After a couple of tacks with the sheets inside I was convinced that the loss of speed was substantial while pointing was little, if any, better and more than lost to increased leeway. I moved them back outside and as it happened, there were a couple of boats nearby on the same tack, and I found that I outpointed one and was moving faster than the other while pointing just as well, so that was pleasing.
DArcy
Feb 11, 2017
1,786
Islander Freeport 36 Ottawa
At least you were out on the water enjoying a sail and learning more about your boat. Sounds like a win!
