With my new trailer I'm addressing the issue using a combination of the ideas above plus my big idea (haha). When I'm building I'm the worst one at taking pictures ( I actually had this thing assembled) but here are a couple to try to explain the design.
In picture 1 you can see the lowered section of the frame cross members and they vary front to rear by 2 degrees, lowering the bow like Gene, but also to give my rudder clearance travelling. 2 degrees on a 26' boat is 12 " bow low which also helps the cockpit drain while on the trailer (center cockpit, scuppers forward).
Picture 2 shows the keel rest looking aft. I have a 9' long shoal keel. The keel rest is sitting on the pivot point (round tubing) on the dolly. This pivot point connects to the first cross member in picture 1. Look close and you will see the tube underneath.
What is yet to be installed, because I need to get the old trailer out from under the boat for some steel tubing, is a 4x3 square tube. This tube connects at the pivot point rises forward at 12.5 degrees between (and connected to) the angle that is sticking forward in picture 2. This tube goes forward, turns up in front of the bow, and will have a bow eye catch. I don't think I will need a winch. At the pivot point there will be 2 hull supports that pivot with all of this mess and several supports on the 4x3 tube. I will have a snug fitting bow guide near the bow eye (remember the boat is coming on level with this support) so the guide will always be at the right place on the bow.
![Er... what? o_O o_O](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
For anyone who is still with me, 1 cubic foot of flotation (FG encapsulated foam) will be attached at the rear of the keel guide in picture 3. Another smaller piece which is adjustable will be attached near the bow eye at water level. I'm hoping someone is saying, aha. This entire assembly will pivot and seek level as the empty trailer is backed into the water. This pivoting assembly allows the keel guide rails, picture 3, to be parallel with the bottom of the keel and not angled up. On a 5 degree ramp all stationary supports will be cleared as the boat floats and the assembly pivots. The unit will work up to a 16 degree ramp before the assembly hits it's stop an inch above the ground. When travelling there are supports installed under the 4x3 at the bow to keep the boat from rocking forward, though the CG of the boat is well behind the pivot.
I'm working on an automated bow eye catch to further simplify (yea right) things.
![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I can't shoot a video until the boat is complete this October. The keel support is painted and under the keel now to support the boat when I remove the trailer.
