Hi,
I have a 2004 B323. Last year was my first year with it and over the Winter I store it in a yard where they drop the mast as the haul the boat via truck about a mile from the water. When we launch they re-step the mast but just get it back in place - they don't tune it.
When they dropped it in the Fall I removed the spreaders. Each spreader has an end cap with a screw clamp per the picture. The shroud passes thru the loop in the clamp. When I removed the spreader I don't recall if that clamp was left loose allowing movement or if it was clamped down holding the spreader tip to a fixed spot on the shroud.. Can anyone help me understand the correct way to re-rig that spot?
Thanks,
Russ
Thanks,
Russ
