That would not be good. Was there much damage...those jack stands look fairly meager. Shouldn’t there be some lateral supports between the stands, like chains or straps?
Yes there was a good bit of damage, about $14K.
The accident had multiple causes. In no particular order:
The keel was not blocked properly, it was only blocked in the middle and not at both ends, this allows the boat to rock fore and aft.
The jack stands were chained, but these are not Brownell stands and they were chained at the top of the stand at the pad. Chaining at this height allows the bottom of the stands to move and dance. Brownell stands chain at the middle of the stand, it helps prevent movement.
The boat sat in a very exposed location with additional windage from the cover. The extra windage no doubt applied extra pressure.
The boat is on asphalt which does not drain. After a freeze thaw cycle we believe some water and then ice got under the stands lubricating them.
The boat was very near the building in the background, there was probably some extremely high localized winds as they bent around the building.
The night it blew over, it was blowing around 40-50 knots.
We believe the wind caused the boat to start rocking and moving, eventually, one stand failed, either it moved or just collapsed, then she fell over, striking the next boat in line, knocking her over, which hit a third boat that laid up against a fourth boat.
Here you can see where the chains were attached. This photo was taken after the boat was upright and in a warehouse. Notice the jackstand handle stuck in the hull. Of course the handle stuck in the only part of the interior that was not easily accessible. The boat is a Sabre 30. Sabre interiors are stick built, except for the sink and head, which are installed as a fiberglass pan. Guess what is on the other side of the hull here.
