Angst
May 20, 2016
3,015
So it could then by all rights be called a glycol pump as opposed to a water pump.........:hook2:
Note above I called it a coolant pump or maybe antifreeze pump in a desperate attempt to not drag in fresh fuel for debate (pun intended)
Schools delayed because snow in Syracuse this morning.
Nice here in Charleston.
Warm weather can’t come soon enough
Aug 1, 2011
3,972
So, is a glycol pump inlet a fresh glycol inlet or a recirculated glycol inlet?
jwing
Jun 5, 2014
503
ODay Mariner Guntersville
In my line of work, all pumps move fresh water. The pumps are not denoted by the fluid (that would be stupid); instead they are named by their function in the process.
Oct 29, 2016
1,929
Hunter 41 DS Port Huron
That would be confusing on a system with multiple processes with multiple pumps per process. In fact not naming a pump by the process it serves would be contrary to many specifications in many installations.
Aug 1, 2011
3,972
Is that toast on one side or two? It might constitute singular or plural.
(and where the sam-heck is @Kermit ?)
Feb 20, 2011
8,062
"Toast" is both singular and plural.
But no, no toasted side at all, therefore "raw".
Now, I'm going to take a hot shower in the backyard.
JamesG161
Feb 14, 2014
7,946
Hunter 430 Waveland, MS
From engineering...
Fresh is moving versus Stagnant which in not.
Water Quality is a different Angst.
Water as a solvent, is a Mixture.
Water, because of it's unique properties and abundance, can be use for Cooling and Heating.
A molecular weight of 17 would be normally a gas at 70°F, but not Water.
CO2 is 22, NO2 =23 etc.
______
To lose the Angst, add more adjectives....
Fresh Sea Water
Stagnant Swamp Water
Cold Drinking Water
Running Hot Bath Water
As a Mixture...
Carbonated Water
Bourbon and Branch Water
Hic!
Water can be used as an Adjective too!
Water Craft, Water Wings, Water Way, Water Balloon.
Jim...
PS: Branch Water doesn't come from a Tree Branch.
Oct 10, 2011
619
Tartan 34C Toms River, New Jersey
Dear God, this thread makes me want to :banghead:only sailors can have a perlonged discussion about WATER!!!!!
Over the past few weeks I'm thinking that SBO should really be OBS, Old Bored Sailors suffering through an endless off season. :)
Likes: Leeward Rail
DougM
Jul 24, 2005
2,242
Beneteau 323 Manistee, MI
I can’t imagine the potential here if all of you could harness the wasted brain power and put it to good use.
Oct 29, 2016
1,929
@DougM I will remind you, brain power consists of energy, which may neither be created or destroyed...... or wasted for that matter..........
So when they burn waste gas at chemical plants in those flames coming out the top of pipes are really being useful. I never heard there use. Perhaps someone with unused brain power can share enlightenment.
Raw water must be different than medium done water. Something like steaks?
3,298
C&C 30 Mk1 Winnipeg
Based on my observation of others, I'd say that if you consume the wrong things, brain power CAN be destroyed. :) Since this is commonly done while in groups, and therefore not an isolated system, this still meets the requirements of the law of conservation of energy
In this thread's case I believe it is more like an ineffective exercise similar to one of those old Suzanne Somers thigh thingies.
I occasionally get into theses type of intentionally goofy discussions on a myriad of topics. I'm just wishing we were in all at Ivan Stress Free Bar doing this. While possibly killing some brain cells.
HMT2
Mar 20, 2014
900
Hunter 31 828 Shoreacres, TX
but I have yet to change to a spring jacket
What is a spring jacket? I have three, one for duck hunting, one for wet, and one for cold! I’m thinking about my poor northern sailing bros while I’m sailing and golfing in shorts. I hope your spring arrives very soon!
