Sure, but does your boat have SEAcocks or LAKEcocks?But here on the Great Lakes we sail on fresh water......
Rawcocks!Sure, but does your boat have SEAcocks or LAKEcocks?
Note above I called it a coolant pump or maybe antifreeze pump in a desperate attempt to not drag in fresh fuel for debate (pun intended)So it could then by all rights be called a glycol pump as opposed to a water pump.........![]()
Thru-hullsSure, but does your boat have SEAcocks or LAKEcocks?
In my line of work, all pumps move fresh water. The pumps are not denoted by the fluid (that would be stupid); instead they are named by their function in the process.Note above I called it a coolant pump or maybe antifreeze pump in a desperate attempt to not drag in fresh fuel for debate (pun intended)
That would be confusing on a system with multiple processes with multiple pumps per process. In fact not naming a pump by the process it serves would be contrary to many specifications in many installations.In my line of work, all pumps move fresh water. The pumps are not denoted by the fluid (that would be stupid); instead they are named by their function in the process.
"Toast" is both singular and plural.It might constitute singular or plural.
My understanding is that it's a fresh glycol inlet with brand new new coolant mix until it circulates once... then it's a recirculated glycol inlet.So, is a glycol pump inlet a fresh glycol inlet or a recirculated glycol inlet?
Based on my observation of others, I'd say that if you consume the wrong things, brain power CAN be destroyed.brain power consists of energy, which may neither be created or destroyed
I occasionally get into theses type of intentionally goofy discussions on a myriad of topics. I'm just wishing we were in all at Ivan Stress Free Bar doing this. While possibly killing some brain cells.Dear God, this thread makes me want toonly sailors can have a perlonged discussion about WATER!!!!!
What is a spring jacket? I have three, one for duck hunting, one for wet, and one for cold! I’m thinking about my poor northern sailing bros while I’m sailing and golfing in shorts. I hope your spring arrives very soon!but I have yet to change to a spring jacket
