Hunter 336 Dinette Table Lift
Feb 28, 2018
10
Hunter 336 Ventura California
There's a rope coming out of the top of the pole that my dinette table moves up and down on. Does anyone know it's function? It currently doesn't do anything. Thanks.
Jul 20, 2005
2,422
Whitby 55 Kemah, Tx
That rope is supposed to be tied to a weight inside the pole and the other end to the table to make moving the table up and down easier.
Jan 4, 2006
7,577
Unfortunately, @Franklin has summed it up exactly.
The only way to access the weight is to drop the mast and go inside the compression post. Wrestling with the table each time you want to raise or lower it would be an easier option:cuss:.
Johann
Jun 3, 2004
570
Leopard 39 Pensacola
The counter weight is likely corroded and stuck in the compression post. I had the same issue. Fixed it with WD40 or PB blaster liberally sprayed down the post, then using a heat gun, mallet, and lots of force on the line to free the weight. Now I just add about 1/2 ounce of motor oil down the post once a year... it’s been fine now for 6 years.
