I asked LasDrop about the retention collar. They said the clamping pressure is so high, it's not necessary. The PSS relies on effectively 2 set screws pressed against the shaft. 2 extra to prevent backout. Good reason to use the collar.
MainSail describes them in his article and he mentions that they are trickier to install correctly.Funny you should say that. I claim ignorance. In all the research I did, I never saw a split coupler, until 38 seconds after the shaft and coupler were ordered.
I’ll change it when the bellows gets done in a couple of years.
A hose clamp could throw your shaft out of balance, saw that on a friends boat last summer. He ended up replacing the clamp with an anode.If you don't have a retention collar, use a SS hose clamp in the mean time.
Have you burped and greased it? When I first got my boat it dropped however once I burped and greased it completely stopped.I also have a Volvo seal in mine, first year I had it, no problems, last leaked about every second day, (about 1/2 quart a day), it will be replaced this spring and I'm looking at a PSS. Great thread!
Yes, I burped it several times, I'm thinking the rubber is just too hard from age.Have you burped and greased it? When I first got my boat it dropped however once I burped and greased it completely stopped.
I wouldn't have thought that a light weight hose clamp could cause an imbalance. Don't notice any imbalance but will take your suggestion and replace with an anode and see if there's a difference.A hose clamp could throw your shaft out of balance, saw that on a friends boat last summer. He ended up replacing the clamp with an anode.
Well, that makes sense, too. I think I'll wait for more input on this before I go to the trouble of turning myself into a pretzel to fix something that might not be broken.You could put another hose clamp opposite the old one, wouldn't that cancel it out?
Yup. I used them on car shafts also, but when you consider a lot of early Chevy's (just for an example), had a shaft dia. of 2.75", compared to a boat shaft of 7/8" or 1",the weight/size of the head of the clamp would be closer to the size of the dia. of the shaft. But maybe I'm wrong on this.That was the old school way to balance an auto's driveshaft. They are larger in diameter though.
PSS got the shaft collar idea from me, from an article I wrote back in 2005 or so. I install them on customers boats because owners have a habit of frigging with things they should not. The set screws can only be tightened ONCE and should never be re-used yet people re-use them far too often.PYI markets the collar for the possibility of a shaft disconnect, but they show it installed behind the PSS seal. Does it have two functions or is it really secondary retention of the SS seal clamp? Regardless. I'm with you guys, for $20 it's cheap insurance. And it can be added without removing the shaft again.
OK, my coupling has been re-used about two times. I am going to have my second PSS bellows replacement. It seems like a new split-coupling would be the way to go. What do you think?PSS got the shaft collar idea from me, from an article I wrote back in 2005 or so. I install them on customers boats because owners have a habit of frigging with things they should not. The set screws can only be tightened ONCE and should never be re-used yet people re-use them far too often.
I can say that in well over 20+ years of PSS experience I have never heard of or seen any evidence of a failure of a "properly installed" & "properly maintained" PSS seal. I know far more boats that have sunk due to traditional packing glands than a have sunk due to a PSS.
A "proper" installation of a PSS always requires a trip to the local shafting shop to confirm proper fitment of the shaft to gear flange coupling. Once you remove the coupling it it is most often done for and can and should not be re-used. Perhaps 1 in 15 is actually re-usable. A shaft collar is a very good idea for folks who fail to ensure proper fit of the shaft to gear flange.
Installing a PSS Shaft Seal
Never mind; I saw your post from 2012 on another forum. Thanks.OK, my coupling has been re-used about two times. I am going to have my second PSS bellows replacement. It seems like a new split-coupling would be the way to go. What do you think?
