The cable from my masthead instruments is a 4 conductor (+ground) shielded cable, with tiny 18AWG wires. I had to replace the compression post (this is a Hunter 34, and apparently everybody else with one of these has already had to do this), and in that process had to cut all the masthead wires including this one.
The only solution I've found to reconnect it is to solder and heat shrink each wire, but that seems pretty primitive. Surely there is a connector of some kind for this? If there is, I haven't been able to find it.
Thanks for any help.
