O’day 27 jib sail help
Oct 26, 2008
6,089
Catalina 320 Barnegat, NJ
I don't think he was being alarmist. If I was a novice and had that stain on the bulkhead below the chainplate I would appreciate someone having pointed out that it was a possible serious issue and to check it out.
I guess I just don't see the stain ... the wood appears to have a very nice pattern and coloration. Sorry, just not seeing a stain. Is it really that obvious? I agree, that if it looks like a stain or otherwise, it should be looked at, but I wouldn't be alarmist based on a grainy photo of wood (teak - possibly varnished or oiled) that has a lot of dark coloration. Wood has an amazing capacity for tolerating wetness periodically without any structural degradation. Even stains can be apparent without any damage. Teak, in particular, is extremely resistant to rot. However, as you know, the teak veneer is backed by a softwood. It is an easy task to suss the condition of exposed wood. The fact that it is exposed will allow the wood to dry easily, making it far less likely to deteriorate. Concealed wood in damp areas is far more problematic and I admit that a stain leading to a concealed location is suspicious. Admittedly, the bottom edge of the plywood is susceptible to damage. My bulkheads suffered damage around the edges that required reinforcement.
I still think the photo doesn't clearly show a problem. Whatsit hasn't suggested that he has seen any damage, just water on the floor, which probably comes from the wire penetration thru the roof under the mast, as has already been suggested to him.
Oct 26, 2008
6,089
Not being alarmist Scott. Unfortunately the wood block under the sole was very poorly designed and sealed. It wicks water like a sponge from the bilge. The tell tale is compression of the sole around the compression post base which allows the water to pool there. Quite honestly I would be surprised if any 27 of that era didn't have the issue it is such an awful setup. Funny thing is I left one of the portlights open in my head when I left the boat. Down came the rain and guess where the water went? Ran to the bulkhead and down to the sole right in the same area. The discoloration indicates standing water at the bottom of the bulkhead and the trail down the chainplate indicates a steady leak. Sadly most O'days have shot bulkheads. It really isn't a catastrophe but should be addressed. The block I refer to is located just forward of the hatch in the sole. It extends forward under the head. A little probing with an awl or icepick will reveal whether this is indeed the case.
Yes, I agree. I am similarly unsatisfied with the construction of my bulkheads. This photo shows the significant stains that I have on my port side as a result of a leaky chainplate assembly. Unknowingly, I varnished the wood, which really led to the stain. The bare wood never showed any sign of leaking before I varnished the wood. I was horrified as soon as these stains developed. I did have degraded plywood around vulnerable edges which did allow some flexing of the overall structure. I fabricated hardwood blocks that I thru-bolted around the edges, which essentially clamped the solid wood of the bulkheads to the fiberglass structure of the boat. It is been far more rigid since I did this many years ago. I made the bulkhead repairs before varnishing the wood, so it was distressing to see the stains appear, but it did lead me to repairing the assembly of the chainplate thru the deck. As you can see, the discoloration is far more pronounced than the photo that Whatsit posted, yet the wood is completely sound in the areas where the stains are evident.
139
O’day 27 Oklahoma City
I looked for more images but that’s the best one. I can’t tell you what it was before I got it 4weeks ago but very dual. I oiled it up a few days in a row. The lying seller used to spray water in every time he’d leave the boat for the week he said. It also had the forward hatch left open for three weeks and got a lot of rain during that time. So the seller said anyways. I’m really starting to panic here. What kind of price tag are we talking? Anything like what you all are suggesting sounds like $1000’s of dollars to get someone to fix this. Any ideas? But again as I said. I don’t remember it looking discolored. A very light yellow at the most but in my mind it was just a clear rain water.
Aug 20, 2010
1,399
Oday 27 Oak Orchard
Let's start with the wires. Go to page 28, post 547 for a look at the mast step. These are the wires you probably have. What happens with the water that can come through them is saturation and degradation of the core under the step. You should see some severe cracking of the gelcoat in this area if this is the issue. Another tell will be water filling the ledge in the cabin liner. There is a pronounced U at the edges by the hull. You can reach a few fingers up there and feel the trough it forms. This will channel the water aft and away from the area. Loads of fun trying to find out where a leak comes from when that has water. Next the wires are between the liner and coach roof so any water will run down the top of the liner into these troughs. Next the teak block with the 6 acorn nuts is the area of staining. Look to the top left for the block and then look at the bottom. It is quite pronounced in the enlarged photo. I don't seem to have taken pictures of the block under the sole. Finally don't get panicky on a repair. For less than a kilodollar you can make a substantial repair which would include new bulkheads if indeed they are punky and you have any wood working skills whatsoever.
Dec 24, 2017
139
Hi Joe
Does this picture help? If you read earlier in this thread I said there were two spots that were kind of “springy”. The one spot of the two is on the top next to the step that I’ve attached a picture on. In fact when my friend stepped up there he said he could hear it crack a bit. He said “you would never win any races with this”. So how hard of a fix is that? But the ceiling in the cabin is very solid.
6,089
Looks like the wiring exits the mast above deck and passes thru the coach roof. It may be a source of water infiltration, so you should repair the penetration with a suitable method that will seal the holes. A soft area around the mast step (base) is not a good sign as it indicates the core between layers of fiberglass is deteriorated. The "ceiling" is a liner. I'm not certain how "solid" it should feel, but it adds no structural support for your mast. It seems that at some point you will need to take your mast down to investigate.
Dec 24, 2017
139
Hi Scott
I’m having the mast taken down this spring. That’s why I was asking if there was a temporary fix until we do that? I need a Crain to help remove the mast and from what I’ve been told is not in service during the winter. And it wasn’t bad is was just a little springy. Also did you notice from my picture that there’s one wire not connected to anything? What does that mean?
Thanks for your time
Pat
Jun 7, 2004
1,250
I believe from the previous posts this is the original O'day 27....not the 272.... I'm happy to answer questions but for sailing the 272...Our club had an older 27, but I'm not really familiar with it...Pat
Dec 24, 2017
139
Hi Pat
It’s the original 27. 1973.
Thanks for your help
Mike
It's a little hard to tell in the picture but it looks like that may be a white coaxial wire? If so it's probably for a VHF antenna, and should connect from an antenna at the top of the mast to a radio in the cabin.
Dec 24, 2017
139
Is there anything I can do to temporarily fix the mast leaking until the spring when I can ge it lifted off?
I think the first thing you'll need to do is figure out where the water is coming from before you'll know what it takes to fix. The posts above have identified a few different possible sources, from external wiring to spaces inside the mast to gelcoat cracks around the step. The possibility of fixing without unstepping the mast will depend on what's really going on. Recommend that the next time you're at the boat you look closer at the area, take some more close up pictures, and try pouring and spraying water in different places to see if you can isolate the water source.
Dec 24, 2017
139
Hi all
I went to the boat on Sunday. If you look at the above picture I posted of my step it shows the wire is loose. Well it was pulled out and water just poured down that hole. My sailing friend sail that’s why the core was getting wet. So hopefully that’s fixed it by me sealing that. And an update. I plugged the boat into electric and all the outlets worked. The lights did not work and the ac did not turn on. So at lease something works. Oh and there was a waist water plug on the Port side of the deck above the head. Well it wasn’t attached to anything and that was leaking so I sealed that well too.
Mike
Dec 24, 2017
139
Your lights are 12v.
Well there’s one with a big new coral light bulb that I wouldn’t think would be. We hooked up a fully charged marine battery and nothing worked either.
Dec 24, 2017
139
Update
All electric working. Air conditioning working too. Put two new lights up. One in head and one in the forward v berth. Looking great. Getting jib sail fixed. Getting paint picked out for spring deck job. Will then fix wet core spots just before. Thanks all for you help and advise.
Now to pick a name.
Happy sailing
Mike
