Yea, but if you drill a 5/16" out to 3/8", you loose the tin plating. A 5/16" won't go on to a 3/8" terminal otherwise.I re-did my 3 batteries and a bunch of other equipment, and they were all 5/16. I think that gives more lug surface to bear on the battery terminal. my 2 cents. 3/8 is just a bigger hole.
Well, duh! I didn't suggest drilling anything. They were all 5/16 studs, so that's the lugs I bought.Yea, but if you drill a 5/16" out to 3/8", you loose the tin plating. A 5/16" won't go on to a 3/8" terminal otherwise.... Ugh! Maybe not a good idea!
I didn't say you did, or that what you did was "Ugh! Maybe not a good idea!" I was talking about my investment in 5/16" lugs.Well, duh! I didn't suggest drilling anything. They were all 5/16 studs, so that's the lugs I bought.
Copper is kind of tough to drill too. It tends to suck the drill bit in pretty aggressively. I've had better luck with a rat tail file. You still loose the tin regardless of how you open up the hole.Yea, but if you drill a 5/16" out to 3/8", you loose the tin plating...
Agreed. I have a tapered, hand reamer that works well, if you are careful to take a very small shaving at a time. The tin can be replace, sort of, with solder.Copper is kind of tough to drill too. It tends to suck the drill bit in pretty aggressively. I've had better luck with a rat tail file. You still loose the tin regardless of how you open up the hole.
So, I found the Greenlee crimper, Greenlee K09-2GL, on eBay, "used once," for less than I paid for the FTZ - so I bought it. I'll be able to compare the tools, but I assume the Greenlee will be superior. I still have the option of returning the FTZ crimper.
What I like about the Greenlee is that it's apparently of much better design and manufacture (made in Germany), and doesn't require adjustment or calibration, as the FTZ tools does. And, it follows the industry standard color code, and the colors are marked on the dies and simply lined-up, not requiring reference to a table.
I'll post a comparison review of the two when I get the Greenlee, and probably crimp a few of the FTZ terminals with the Greenlee, to see how it does.
I wish I had done some more research before pulling the trigger on the FTZ, but, oh well, that's how it goes sometimes.
I'm not suggesting drilling lugs but here is a safety tip when drilling copper, lead, brass, bronze or plastic. A standard twist drill has a positive rake at the cutting edge which sucks the drill into the metal. The cutting edge needs to be ground to a zero or - 2 degree edge. A standard bench grinder will work but may result in asymetric edges causing drill wobble and less than round holes. For other than high precision holes it is acceptable. A straight flute gun drill with 0 degree cutting edge is the best solution but the twist drill is acceptable otherwise. These edges allow the metal to be chipped away rather than torn.Copper is kind of tough to drill too. It tends to suck the drill bit in pretty aggressively. I've had better luck with a rat tail file. You still loose the tin regardless of how you open up the hole.
Yikes! Well, we'll see when I receive this one. I assume I will be able to tell if it's a knock-off, by a close inspection, and test crimps. Bummer.The main reason I do not recommend the Greenlee, in my article, Making Your Own Battery Cables (LINK) is due to the massive counterfeit issue with those tools.
Back in my machine shop days, we would grind shallow clearance angles on standard twist drills for use in copper & it's alloys. That worked well. I never tried going all the way to zero clearance angle. We usually used something in the 3-5⁰ range for drills that would be used in a press or mill & sometimes cowboy'd it up to 7⁰ or 8⁰ for bits to be used in a hand drill. The steeper angle in the hand drill would reduce the pressure needed, at the expense of a greater possibly of hooking up & digging in. You had to be careful with those. Standard general purpose bits for mild steel were ground with a clearance angle more like 10-15⁰. Bits for use in stainless & aluminum got clearance angles closer to 20⁰ of relief.I'm not suggesting drilling lugs but here is a safety tip when drilling copper, lead, brass, bronze or plastic. A standard twist drill has a positive rake at the cutting edge which sucks the drill into the metal. The cutting edge needs to be ground to a zero or - 2 degree edge. A standard bench grinder will work but may result in asymetric edges causing drill wobble and less than round holes. For other than high precision holes it is acceptable. A straight flute gun drill with 0 degree cutting edge is the best solution but the twist drill is acceptable otherwise. These edges allow the metal to be chipped away rather than torn.
That will definitely help but for the average guy grinding a clearance angle is pretty tough. The easy way is the "dubbed" drill.Back in my machine shop days, we would grind shallow clearance angles on standard twist drills for use in copper & it's alloys. That worked well. I never tried going all the way to zero clearance angle. We usually used something in the 3-5⁰ range for drills that would be used in a press or mill & sometimes cowboy'd it up to 7⁰ or 8⁰ for bits to be used in a hand drill. The steeper angle in the hand drill would reduce the pressure needed, at the expense of a greater possibly of hooking up & digging in. You had to be careful with those. Standard general purpose bits for mild steel were ground with a clearance angle more like 10-15⁰. Bits for use in stainless & aluminum got clearance angles closer to 20⁰ of relief.
I've only ever seen gun drills used for very deep holes. I never thought to try them for shallow holes in cupric alloys. That's an interesting idea.
We used different grind angles for specific different plastics. Poly carbonate would usually tolerate standard twist drills. Acrylic (that is often used for boat windows) usually got a very pointy bit that had a point geometry similar to a spot bit to prevent cracking the material around the hole.
I usually don't go into this much detail about drill tip geometry with people who don't know how to read a drill point by looking at it from the front, but since the subject was brought up, I figured that I would take a chance & babble on a bit.
Just a suggestion, maybe you could put a short blurb in your article about this counterfeit tool issue. I would have been much more circumspect had I suspected that was an issue.The main reason I do not recommend the Greenlee, in my article, Making Your Own Battery Cables (LINK) is due to the massive counterfeit issue with those tools. While the genuine tool works pretty well the knock-offs do not.
I contacted Greenlee technical support asking how to identify a genuine tool, or a counterfeit one. I also asked the seller of mine where he got it, and for any documentation he might have.
Well, if mine turns out to be a fake, it would have saved me $170!It's really not worth it...
