Cetol, brush or rag
Jul 13, 2010
1,100
Precision 23 Perry Hall,Baltimore County
Sanding and refinishing the tiller handle. I have had this boat 4 seasons,never been done. Looked all over this site,archives,past discussions, answers are all over the map, so let's do it all again tonight. Thanks.
Oct 24, 2010
2,405
Hunter 30 Everett, WA
I used a brush/ never tried a rag. It seemed to have good performance as wood finishes go. The appearance is different from varnish. I prefer the longer maintenance interval over the better appearance of varnish.
Ken
Likes: Parsons
-na -NA Anywhere USA
The first coat or two of Cetol used by me personally and as a dealer now retired, I use to cut the first two coats by 50% with a thinner. This allows penetration into the smallest of pours or pores to be filled where applying a regular coat will not. Just one way to make darn sure water cannot penetrate into the wood learned from some old salty dogs in this industry who are well known.
Likes: Parsons
Aug 2, 2005
1,155
+1 for Ken's comment and +1 for Crazy Dave's comment - sounds like a good idea (although I have not thinned the Cetol). I will try that next time. Personally, I do not like the look of the "gloss" type of Cetol. Cetol is a soft finish, and I don't think the shine will endure. Oh, wait a moment. My wife does all the refinishing of the bright work so my opinion probably does not really matter!
Carefully mask fiberglass and metal areas if you are refinishing wood that is not removed from the boat.
Jul 13, 2010
1,100
Tiller Is on the workbench,rainy day job. Hope it's ready by May.
Oct 10, 2011
619
Tartan 34C Toms River, New Jersey
I did my tiller with the gloss. I just followed the instructions. The tiller was sanded smooth before applying. After 3 years I just did it again. I am very pleased with the results.
Jul 12, 2011
1,165
Leopard 40 Jupiter, Florida
I've never thought of a rag for finishing. That said, I recommend the absolutely highest quality of bristle brush that you can get. Half of my 'oops moments' from finish painting / staining have been from bristles left behind or not spreading evenly. Don't save the $5 in your brushes.:doh:
Nov 6, 2006
10,208
Rag with linseed oil or teak oil or some Formby's, but not Cetol.. A good brush and the results are fine..
Oct 25, 2011
576
Island Packet IP31 Lake St. Louis, Montreal
A disposable foam brush also works very well. No wayward bristles either.
Matt
Likes: Fred
Mar 3, 2003
710
Hunter 356 Grand Rivers
I use cheap brushes and sand to a fine finish then apply multiple thin coats over several days. Let the coats dry completely before recoating. I do mine in the winter and will put 12 to 15 very light coats on. I will lightly sand between the coats if I get a buildup. I occasionally have a bristle come out, but just remove with my finger and redcoat and spread the catol thinly over the area while still wet. Just don’t leave a bristle caught in the finish.
I’m sure fine brushes will do a better job, but I get a very good finish and go through about 10 of those cheapest Lowes brushes. I re-coat from scratch about every 7 to 8 year’s. When I have a thin spot I use fine sandpaper to sand lightly and use the same technique over the smaller area carefully blending in and sanding everyb3=or 4 coats with very fine grit.
Jul 13, 2010
1,100
Still remember the photo of her with the chain saw! You have a keeper there!
Jul 13, 2010
1,100
Yeah,I badly messed up the reply trying to quote Phil about the wife doing the brightwork. I remembered a photo of his wife with a chainsaw doing yard work. VERY impressed!
Before finish is applied, you can wet and let dry then, sand, several times. This causes the loose grain to fur up. With 220 to 300 grit paper, knock the fuzzy grain down and re-wet to do it again. Don't sand when wet. The end result is a very smooth surface that won't fur when that first coat of finish is applied. I like the thinning of the finish for the first coat idea. Then sand to nearly bare grain again. This gives you tight filed pores upon which to build your coats. I also don't sand any finer than 300 grit until the second to last coat, that coat is 400 and up. The final coat doesn't get sanded unless the type of finish calls for it. Usually, there's no buffing as smooth as that last coat. A quality brush is absolutely necessary or the streaking may nor settle out. Oil finishes are best finished with a cloth. Seal the grain and sand between coats of oil.
I've been a cabinet maker most of my life and recently started making art enhanced wooden parts like doors and hatches. Check out my new wood burned hatch boards I made for my boat Dragonfly. It's my profile icon. My new art.
I don't know anything about Cetol but the water-based spar varnish I used is fantastic. It is called UltraGold. Been on my kitchen counter for about 10 years, nothing gets through it. Never added more coats, 5 on the countertop, 8 on my hatches. The makers claim it out performs oil-based vanished for UV protection. It sure is easy to clean up and doesn't smell.
I like the cheap brushes from Lowes because I just throw them away instead of cleaning them but, even if they don't leave bristles in my work, they don't lady down the finish as smoothly. Its a very noticeable difference.
- Will (Dragonfly)
619
- Will (Dragonfly)
Very nice Art Work, and a load of valuable wood finishing information. Thanks Will.
Thanks for the compliment. I wrote up and posted the hatch board project on the mariner association web site. Didn't know how to get the pictures to post inline with the text so it turned into 9 pages of separate posts, just to keep the images associated with the right paragraphs. If I figure out how to do that here, maybe I'll repost it on SBO.
I think sailboat owners like projects more than other groups of people. More independent minded.
- Will (Dragonfly)
May 7, 2006
249
Catalina 28 Mark 1 New Bern
Which thinner would you use to cut Cetol
Jun 9, 2008
1,850
- -- -Bayfield
I always liked varnished tillers myself, but Cetol is easy to use. You can gloss it up with their gloss, but that is applied over their other Cetol products of your choice. Like varnish, the more gloss, the nicer it looks. I brush it on and then because I don't like the blotchyness (is that a word?) of Cetol that is just sitting there and not saturating into the wood grain, I then take a cloth and wipe it down some, which keeps the painted on look away. To each their own.
