Hunter 50 AC watermaker
Aug 24, 2015
36
Hunter 50 AC Racine, WI
I have a 50 Hunter and am looking to install a water maker. I am curious to anyone that has one installed from the factory to the location they use for this unit?
Thank you
SG
Feb 11, 2017
1,670
J/Boat J/160 Annapolis
Why are your doing this? Are you in Wisconsin?
We have a very reliable, but almost NEVER really used Village Marine unit (Now Parker owns Village Marine, but..)
Why don't you talk about where the boat is, what, where you'll be sailing, how often, etc. "The program"
Then you might get some reaction on which units, access, physical requirements, etc....
Jun 6, 2006
6,990
agree with SG, if you are in the states they a rain collection system makes more sense. Depending on where you sail a water maker can make sense but at $1000snads of dollars You would only want one if you plan on sailing where it does not rain often.
SG
Feb 11, 2017
1,670
Rain collection isn't nearly as easy or effective as a hose from the municipal water or other drinking water source :^)))
You might even fill it from the Lake Michigan with a little chlorine bleach (VERY LITTLE) to purify it, if you're concerned. If you were offshore, I'd think that a "fresh water" wash down pump and clean hose could fill your tanks.
Aug 24, 2015
36
Just looking to see where the factory unit is installed. We are headed to the Caribbean.
Oct 27, 2016
0
Seattle
And now a word from the sponsor...
Cabinet catch for many Hunters
These catches were common on Hunters from the Legend-era through today's Marlow-Hunters. We keep a large stock on hand for emergency shipments or just getting spares.
See the product
Feb 16, 2012
198
Hunter 45 CC Alamitos Bay, Long Beach
Thank you
MC,
We have a Hunter 45 CC, and have installed a water-maker. I have only seen the Hunter 50 at a boat show. On the Hunter website there is some information on installing a water-maker on the 45 CC. It will give you some ideas. First go to the "Hunter Model Information Center", the go to the "Hunter Information Center", click on "Downloads Hunter 45 CC. scroll
down to "Hunter 45 CC Water-Maker" open it up and there is 10 pages of installation information on the Seafari 170/350 U.S. GPD, Reverse Osmosis Desalination System. Hopefully it will give you some ideas for a similar installation on your boat. If you have any questions, PM me and I will give you any help I can.
Jeff
Aug 24, 2015
36
Thank you for the direction, I recall this as part of the old hunter website but do not see it under the Marlowe-hunter website? Do you have a link?
Aug 24, 2015
36
Found it, thanks for the direction. I am looking to put a larger one in but this gives me an idea of what they did from the factory.
1,881
Hunter 49 toronto
If you look in the Hunter online technical documents, navigate to the H49.
There is a full write-up c/w photos on how they install a water maker in the 49. This would be identical for your boat.
The wm version will be newer, but it shows you how to do the piping, etc.
Aug 24, 2015
36
Thank you for the direction however I found the files for the 49 but do not see anything in there for the watermaker?
Jun 1, 2009
1,881
Hunter 49 toronto
You are right. It's not there.
But,,, it was. Not sure why it was removed.
Contact Hunter. They have the document.
Basically it mounts under the settee stbd side. (In board locker)
The pump & filter mounts under floor on centre just forward if the batteries.
Plumbing is simple. They just T it into the water tank input. The tanks self-level, so you only need to plumb it into one.
But, there is a full write up with photos somewhere on the Hunter servers .
Jun 1, 2009
1,881
Hunter 49 toronto
The 45 water maker install is very different from the 49. I just read the 45 install procedure, and there are significicant differences.
Once you get the document from Hunter, could you post it to the site??
Jun 15, 2012
717
BAVARIA C57 Greenport, NY
This is completely off topic. Anyone know what brand the alternator is that Hunter installed in my 2011 Hunter 50? It is painted red, with a single groove pulley and I have not seen an external regulator. I think it is 100 amps and is not a Hitachi. It has stopped working, and I need to pull it out.
Jun 1, 2009
1,881
Hunter 49 toronto
Boy, that's odd.
If it doesn't have an external regulator, it must be stock Yanmar.
The upgraded alternatives that Hunter installed were Balmar, and the external regulator was ARS. It was mounted on the bulkhead above the engine .
Question,?
Have you changed your water pump yet to make the impeller accessible?
Aug 24, 2015
36
My boat is a 2011 Hunter 50, this was the first year that they started using an Electromaax alternator although it is not as you described. Can you take a picture of it and I can tell you if it looks like mine. Mine has an internal regulator but is aluminum in color, no red.
If indeed the alternator is bad, I would recommend switching to the Electromaax, it puts out over 150 amps at idle! I know the owner so let me know and I will assist where I can .
Jun 15, 2012
717
Art, haven't done the relocation yet. It will be a winter project.
mcconkd, Thanks for the offer. I haven't planed on going thru the expense of changing the v-belt to a serpentine belt as I think 100 amps would be ok. We seem to always need to run the generator anyway. Any thoughts appreciated.
Aug 24, 2015
36
You will be happy making the change. We almost never run our gen set unless we need to use the air for the kids whil sailing. The difference is amazing. Go the the electromaax.com website to see what there alternator looks like. With the serpentine belt set up the belt never slips thus no small little rubber pieces all over from the v belt.
Jun 1, 2009
1,881
Hunter 49 toronto
I will have some photos of the anti rotation bracket soon. Forgot to take them when I installed it. Will do so when winterizing
