Trailer launching with extension
Jul 5, 2017
66
Hunter 25.5 Arizona
So I'm getting close to being able to launch this Hunter 25.5. It has a 20ft IMG_20170819_121752.jpg IMG_20170819_121800.jpg IMG_20170819_122151.jpg long extension bar included with the trailer that attaches to the truck receiver with a tongue and the trailer with a ball mount as pictured. I'm wondering if anyone does it this way and how it works vs. taking off the tongue and removing the receiver from my truck and pinning it through there. The lakes I will be sailing at have rather long launch ramps so I'm thinking the extra pivot point will be problematic like when I back up tandem trailers at work. Thoughts?
Sumner
Jan 31, 2009
5,254
I've never done it or seen it in play but probably youtube videos on how others do it.
I envision backing the trailer down to close to the water's edge on the ramp and then blocking the wheels and unhitching from the tow vehicle. Pull it forward and attach the tongue extension. Then pull ahead just enough to get rid of the blocking and then backing the boat down into the water.
You would never be pushing the trailer while it is attached, just letting it go backwards with gravity on your side or forwards when you retrieve. I would do more research for sure but this is how I would envision doing it.
A number of ramps I've been to would not be long enough to do the above. The trailer would drop off the end of the ramp into a hole. I'd make sure the ramps you want to use are long enough,
Sumner
1300 miles to The Bahamas and Back in the Mac...
Endeavour 37 Mods...
MacGregor 26-S Mods...
Mac Trips to Utah, Idaho, Wyoming, Canada, Florida, Bahamas
Likes: LloydB
Jul 5, 2017
66
Hunter 25.5 Arizona
Yeah they should be long enough, as both lakes I expect to go to are used regularly by sailboats and both had their dams raised by 80 feet or so which meant the ramps had to be extended. What concerns me about doing the block method is the ramps tend to be really slippery at the waters edge to about 15 feet or so up. It's that heavily channeled concrete, where the channels are about an inch and a half wide by one inch deep. In Mexico I'll just pay to have them launch it as they have special built tractors with the engine about 10 feet in the air. The guy I bought it from included some heavy rope that was double braided into a chain of sorts and said he used that!
Mar 13, 2011
175
Islander Freeport 41 Longmont
I had a hunter 25 (older version with a full keel). The extension might work but most likely only the steepest ramps can use it. As mentioned back down to waters edge, block the trailer and then pull up to use the extension.
On the other hand, I ignored the extension with my boats and used the strap method, two lengths of 30' 30lb nylon strap linked to trailer and truck. Plenty of room to ensure the trailer is in and the truck always stays dry. We launch boats up to a Catalina 30 at our club with this method and have for the last 20 or so years. Works great and isn't hard to learn to maneuver the trailer with the strap.
Good luck
Aug 1, 2011
3,972
Mine is aluminium tube so the trailer is limited to straight line only. It's a small price to pay for the weight savings, and it requires diligence at the ramp.
May 24, 2004
7,198
CC 30 South Florida
These are used in ramps that are long with a shallow slope to permit floating the boat without having to submerge the tow vehicles wheels. Yes you have to unhitch the trailer, hitch the extension bar to the trailer and then hitch the assembly back to the tow vehicle. Most of the time it is just easier to find a ramp with a deep slope but on occasions you may find yourself with a shallow ramp being the only alternative. Always consult with local knowledge about where is what lies beyond the end of the ramp, a smooth bottom or a large drop off.
Sep 15, 2016
841
Catalina 22 Minnesota
There are lots of gray threads on how to use extensions for launching. Here are a couple that helped me.
https://forums.sailboatowners.com/index.php?threads/trailer-toungue-extension.181585/
https://forums.sailboatowners.com/index.php?threads/a-question-of-balance.184405/
What others have said about the end of the ramp is absolutely true. I was at a lake in WI this summer and was loading the boat with the extension when I needed to walk back to the axel to adjust something. I fell off the ramp into likely 8 feet of water where the sand was blown out from under the ramp from the power boats launching. When I stood back up on the ramp my tires had less than 6 inches before they would have fallen off likely damaging the axel and trailer.
Once you learn your local ramps though it's no big deal to launch with the extension or strap method I do it every time I launch. If your extension mounts to the trailer firmly then you can extend it before approaching the ramp so long as you don't make to many tight turns but if you have to leave your wheel jack down for support then you want to be lined up before you install it. Try hooking it up in your drive way to get the feel for how it works and if you can post some pictures of it deployed likely someone here can help with more advice on how to make it as efficient as possible at the ramp.
And what every you do do not pin the extension directly into the hitch after removing the ball portion. The load forces will tear your mounted hitch right off your truck with that much leverage.
Sep 6, 2015
110
Unknown snipe delaware bay
I made my trailer extension permanent. It solved the problem of beach launching, and shallow long ramps. It made driving to the launch site only slightly more difficult than when the trailer was shorter. I also cut the ball receiver off and opted for a pintle ring. I have no faith or patience for a ball coupling.
YMMV
Eric
Jan 8, 2015
360
MacGregor 26S, Goman Express 30 Kerr Reservoir
So I'm getting close to being able to launch this Hunter 25.5. It has a 20ft long extension bar included with the trailer that attaches to the truck receiver with a tongue and the trailer with a ball mount as pictured. I'm wondering if anyone does it this way and how it works vs. taking off the tongue and removing the receiver from my truck and pinning it through there. The lakes I will be sailing at have rather long launch ramps so I'm thinking the extra pivot point will be problematic like when I back up tandem trailers at work. Thoughts?
Yes, the extra pivot point could be problematic. I used a similar setup as your recently and I addressed the situation at the opposite end that you are thinking of. I fastened the extension firmly to the trailer tongue so it couldn't pivot there.
I used trailer axle style U bolts to hold things together.
Jul 5, 2017
66
Hunter 25.5 Arizona
Thanks for your input everyone, I think I will modify the trailer side so it doesn't pivot at the trailer connection. Luckily I have a welder and haven't had anything I've welded break so this shouldn't be difficult
Likes: waterpirate
Jan 8, 2015
360
Cowpokee are you having to use that with the MacGregor?
Sumner
No. That was used on my 30' Goman Express.
-na -NA Anywhere USA
@Submarine
As a dealer, several of my trailers had long extensions. There is a lot of information but would take too long to write. Be glad to discuss my technigques and I was use to off loading up to the Hunter 340 with a tandem axle with long extension and retrieve it. The first thing I can tell you is that attachment chains are needed regardless. As suggested you need to know the ramps and check with the locals as they will know more than the far away week end warriors. Feel free to contact me. Even launched from bulkheads and over bridges.
Crazy Dave Condon
