Injectors
No direct experience with your Westerbeke but on my 42B, I removed the supply and return fuel lines and the injectors were held down with a u shaped bracket with a nut on a stud that held the injector in place. Once every thing is cleared I gently moved the injector back and forth until it became free. They were a VERY tight fitting. From there on they lifted out. I numbered them for reference. After testing and rebuilding, the rebuilder also included the crush washers, one under the injector and two for the fuel line. Interestingly, there was no crush washer under the injector when I removed it. After rebuild, I no longer had to use wide open throttle and now seldom use the preheaters to start the engine.
Alan J C400
