So today I took off my heat exchanger cap to see how it looked. Turns out there is a piece of old impeller in there. So it's good I looked.
My issue is that there is a strange seal on the cap that I can't seem to find online. The one that came off in pieces is round, but it has a little divider to keep most of the flow down on the inside 8 holes. When I look online it shows a normal o-ring instead of one with a divider... In all honesty I'm sure the divider is not that necessary as most of the flow is directed at those holes anyhow. Anyone know where to find a gasket like that? It was so brittle.. I'm not sure if it was a gasket or O-ring.
Thanks for any insight. And I do plan on cleaning it up before re installation
Thanks, Chad
Thanks, Chad
