I am getting ready to launch my 240 for the first time (for me!)
Yesterday I stepped the mast and put up the sails in the driveway. Everything went pretty good, but one problem came up as I was going through the process.
When I lifted the mast from it's "nest" in the bow rail, slid it back through the mast crutch and set it nicely down in the mast base plate; the hole in the casting at the base of the mast doesn't line up with the hole in the stainless steel mast base bracket that is fastened to the deck. In fact, it misses the hole by about 1/2"! It appears like the mast is 1/2" too long. There appears to be evidence of many previous mast raising attempts as well. (the stainless bracket and the screw heads are all chewed up from other people using pry bars to align the holes)
I had to use a pry bar to force the mast aft until the holes aligned. I can't imagine that is normal. Any ideas about what might be going on there. The boat appears to be excessively stock. The guy I bought it from has taken excellent care of her. He mentioned it was like that for him as well.
