propeller paint
Dec 30, 2009
680
jeanneau 38 gin fizz sloop Summer- Keyport Yacht Club, Raritan Bay, NJ, Winter Viking Marina Verplanck, NY
happy Easter all...I've got a question on prop, I just bought a new one and wondering should I paint with the Petite prop paint, I'm in Keyport NJ salt water?
Likes: Captn Scotty
Dec 25, 2000
5,932
No paint on the prop here. A diver cleans off a few barnacles each year then clean and polish every seventh year when I redo the boom paint at haul out. Original 1991 prop has always been in sea water; looks like new after polishing. Two zincs on the shaft.
Nov 26, 2012
2,315
Catalina 250 Bodega Bay CA
If that prop is brass or bronze I would not paint it. Probably not since it is a new one. Chief
Beneteau 323 Annapolis MD
[QUOTE="redhead78, post: 1367578, member: 93586] ...should I paint with the Petite prop paint, ?[/QUOTE]
I'd leave it gold plated as it is.
Likes: wsmac
Jan 27, 2008
3,086
ODay 35 Beaufort, NC
I tried the Petit spray paint and barnacles, oysters, and assorted soft critters love the stuff. From what I can tell it had no effect. I dive to clean it myself so I had a pretty good view of it. Last haul out I tried a thin coating on the prop of WEST epoxy followed by some hard bottom paint. I figured the epoxy would insulate the prop from the paint and I hot coated it for adhesion. I just hauled out and the outer half of each blade is bare with just baby barnacles on it. If anyone has the ultimate solution I'm all ears.
7,435
Alden 50 Sarasota, Florida
There is no definitive answer to this. I used it regularly when we were in Narragansett Bay and the Petit prop paint was very effective in minimizing growth and critters. Here in Florida, it's essentially useless.
The only thing about which you can be assured is that it won't hurt anything so why not try it?
Mar 15, 2013
197
Islander 32 mkll Comox Hrb.
I'm going to try lanolin on my prop this year, but we don't get the same rate of growth as in Florida!
Jun 5, 2004
485
Hunter 44 Mystic, Ct
I've used the Pettit prop paint for years hear in the Northeast and truly believe it does an excellent job of protesting my prop and shaft.
Apr 18, 2008
77
O'Day 34 Fairfield Harbour, NC
I used Zinc based cold galvanizing spray cans from Lowe's. Gave several coats with sanding in between. Made a smooth, hard surface that held up well.
Jun 14, 2010
2,348
Lanolin doesn't work, and it doesn't last either. I've tried all kinds of things and I think zinc spray paint is just OK, and better than nothing. Pettit prop guard (a lower cost alternative to propspeed) workers OK also but it takes more time to apply the coats. I've also tried Pettit Vivid bottom paint (it's a hard ablative) and that works well but might cause electrolysis.
Sep 23, 2009
1,475
Practical Sailor did a test on them if you can get to it. One important note: don't paint the anode.
https://www.practical-sailor.com/issues/37_75/features/Propeller-Paints-that-Last_12173-1.html
In this case, screw practical sailer and shame on them. Far more pratical is zinc primer from your local hardware store.
Barnacles use to be a real problem when I coated our shaft and prop with anti fouling paint. Someone here was kind enough to post the results of a test at their club. Based on that I used hardware store zinc primer last spring and in the fall had a virtually barnacle free strut,prop and shaft. The 6 dollar can will last me three or four seasons. It doesn't get much more practical than that.
Apr 8, 2016
114
Beneteau 361 Clipper Garrucha, Spain
Red, assuming you upgraded from a two blade to your new shiny 3 blade, would you mind adding to this thread what engine you have and did you notice any improvement in performance once back in the water please.
Jul 7, 2004
8,492
Hunter 30T Cheney, KS
the same article said regular anti-fouling paint doesn't work on props
-na -NA Anywhere USA
The biggest issue is adhesion to the prop. Years ago I was told a process with a tye coat and so forth. Not sure about the new spray paint from Petit but will find out what I was advised and get back with you all. It worked for me as a dealer in North Carolina
Jan 27, 2008
3,086
Seems to make sense, I don't remember barnacles attaching to my shaft zincs. Maybe zinc is toxic to them? I'll give it a try. Thanks.
Hafa
Jan 24, 2017
28
Hunter 40.5 Saipan
OK, I'm not Red, but we did upgrade from a 2 to a 3 blade in 2015; motor is a Yanmar 4JH2E, boat a Hunter 40.5. The difference was significant. Motoring was noticeably smoother and we went from ~5 to ~6 knots at 2000RPM in calm seas, 10kts wind on the beam for each test.
Likes: onlinelee
Dec 30, 2009
680
my motor is a Kubota 35hp 4cyl, It has not hit the water yet Ill let you know, I'm looking forward to better performance when reversing too, we'll see..Red
Oct 5, 2015
80
Hunter 33 33 Halifax
I used Rust-Oleum Cold Galvanizing Spray Paint from Kent last summer (based on a number of recommendations) and virtually barnacle free strut, prop and shaft as stated in a previous thread. Before that I tried a number of products with various results. For the dollar value I will be using the same product again this summer unless someone comes up with a better bang for my buck.
