Universal diesel. It was the fuse holder.
Oct 9, 2008
1,742
Bristol 29.9 Dana Point
So my starter has always had an intermittent clicking problem. 84 M-18.
I was aware of the known wiring harness and fuse holder issues for these motors documented here on SBO, and for the wiring harness charging circuit documented issue I had proactively replaced the ammeter with volt, and bypassed the charging circuit to charge direct to the batteries.
However, I had also checked the fuse holder at the engine for the solenoid, because of the clicking, but fuse holder looked fine. No corrosion or frayed wires etc. figured it must be a sticky solenoid, even though that specific fuse holder had been identified repeatedly on SBO regarding these older motors as a likely culprit for misbehaving starters.
Not going to replace the holder. Guys on SBO are wrong in my case here.
Anyway, the motor always started. Sometimes it would click, sometimes it wouldn't. When in clicked, I'd just jog the start button till it caught. Figured I'd replace the solenoid if it ever got worse. But it never failed, so I just got used to the clicking.
6 years now. Click click click.
Well, last week at Catalina Island, I wrapped a trash bag up in the prop. Harbor patrol boat came around and cleared it with a boat hook so I could get to a mooring. When they cleared it, they said, "Ok, try it now".
Click click click click. Click click start.
I was embarrassed. Everything on a boat should work properly.
So decided to dig into it all the way and fix whatever it is.
First thing I did was check that fuse holder again. This time, I looked at the fuse. Something odd - Saw it had been arcing. For a long time. (Picture)
Replaced the fuse holder with a heavy marine grade thing I had in stock.
Aaaand.....
It was the fuse holder the whole time.
Motor starts right up repeatedly now. It even sounds different. Like it's engaging faster. A clean snick and start.
Guess I missed the humor. :)
Glad you're happy, though. :)
Beneteau 323 Annapolis MD
Six years, eh? Yeah, no point rushing into something you're not sure about. :)
Oct 9, 2008
1,742
Yes!
Especially since I was leaning towards the solenoid being the problem. With my mediocre-at-best engine access, I would have had to remove the exhaust manifold to get it out. Huge pain.
Anyway I had checked that damn fuse holder and it was fine.
Fine I says.
:-D
Gremlins. They always get in the way of our seeing the real problem. Glad you beat them away and found the real problem not the symptom.
The good news you solved that one. And no need for taking all the access restricting engine parts off only to discover some other waiting gremlin... ;)
That will still be there for another day.:yikes:
Likes: Ron20324
Oct 9, 2008
1,742
Yep, that's always a valid concern:
Initiating a repair job so that I can break something else in the process.
