Should have new charger and battery bank installed soon... with help from this forum and guidance from KZW. Thanks.
I was surprised that the promariner tech recommended a 60 amp charger. It is the Pronautic 60. The old charger was 20 amp and I have read that many use a 20 amp.
If I have the formula right... a 20 should work fine but the tech said it would be undersized and could lead to early unit failure.
Total amp hours of house bank will be 430.
Amp hours of starting battery is 105.
Example: if house bank is depleted 50% then
215 amps / 20 amp = 11 hours charge time
Comments?
Thanks
Comments?
Thanks
