I am redoing the mast while it is down. They had the masthead light and the all around (anchor light) wired together. I would think they would need two separate switches.
Dan
Dan
Not totally true.The all around light at the top of the mast is an anchor light. Only lit when anchoring or when trying to confuse those who understand boat lights.
I was standing on the bridge of a ship when I first encountered a masthead tricolor. It appeared as a disembodied colored (I don't remember whether red or green) light far off ahead. As I walked from the bridge wing to the radar to check it out, I saw the light pass by the open bridge wing door out of the corner of my eye! I raced back to the bridge wing and watched as a sailboat slid down my ship's side, not 15 feet away.Capta. In the area of civilization the masthead nav lights can be confused but in a sea where the boat disappears from view the masthead may be more visible to a large ship than the deck level nav lights.
The white 360 light (like an anchor light) can be used in lieu of a mast steaming light according to CG Nav Regs.
The same 360 white light, alone. Read my comment about how to call lights in the post above.Then what do you use for an anchor light?
Well not exactly. Rule 23:Not totally true.
A 360 all-around light combined with forward red-green sector lights is a perfectly acceptable way to light a sailboat while motoring.
Please. ;^) Any one of these are good for a vessel under 12m, the case I mentioned is number (d) (1) in your list. When I got my ICC certification last month, I have to learn more about this then I ever wanted to know!Well not exactly. Rule 23:
Rule 23 - Power-driven Vessels Underway
(a) A power-driven vessel underway shall exhibit (click on icon to see picture![]()
(i) a masthead light forward;
(ii) a second masthead light abaft of and higher than the forward one; except that a vessel of less than 50 meters in length shall not be obliged to exhibit such a light but may do so;
(iii) sidelights: and
(iv) a sternlight.
(b) An air-cushion vessel when operating in non-displacement mode shall, in addition to the lights prescribed in Rule 23(a), exhibit an all-round flashing yellow light, where it can best be seen.
(c) A WIG craft only when taking off, landing and in flight near the surface shall, in addition to the lights prescribed in Rule 23(a), exhibit a high intensity all-round flashing red light.
(d) (i) A power-driven vessel of less than 12 meters in length may in lieu of the lights prescribed in Rule 23(a) exhibit an all-round white light and sidelights.
International Inland
(ii) a power-driven vessel of less than 7 meters in length whose maximum speed does not exceed 7 knots may in lieu of the lights prescribed in Rule 23(a) exhibit an all-round white light and shall, if practicable, also exhibit sidelights.![]()
(iii) the masthead light or all-round white light on a power-driven vessel of less than 12 metres in length may be displaced from the fore and aft centre line of the vessel if centreline fitting is not practicable, provided that the sidelights are combined in one lantern which shall be carried on the fore and aft centre line of the vessel or located as nearly as practicable in the same fore and aft line as the masthead light or the all-round white light.
(e) A power-driven vessel when operating on the Great Lakes may carry an all-round white light in lieu of the second masthead light and sternlight prescribed in Rule 23(a). The light shall be carried in the position of the second mastheadlight and be visible at the same minimum range.
If used, the all around light needs to be in the abaft position, the masthead would not be in the abaft position on a sailboat.
Here's a link to the official rules: Navigation Rules - Amalgamated See Rules 23 and 25.
For sure it down to personal opinon, and personal choice. The Lab (which I personal agree with) says that you can SEE and FIND the masthead light better, which is job#1. Then you use your binocs to gauge range and better ID.I agree with Capta, the colored nav lights on the bow with a white stern light at night helps determin distance far better than the tri-color on the mast head. Can the OP Skipperdan determine if this mast head light is the steaming light? (We have a tri-color but will only use it if the lower nav lights crap out.)
All U Get
You are 100% correct. Those two lights should NOT be wired together.I have a round 360 white light on top of the mast. I also have a forward to side white light about 12" down from that. I have a white stern light on the hull. I have a red and green light forward on the hull.
The two mast lights were wired together is why I asked. I think they need to be separate, otherwise my anchor light is lit while motoring.
Jack, that's just not my reading of the rules. Masthead (225 degrees) forward, stern light aft (135 degrees), see Rule 21 Definitions. Functionally, the two lights form a 360 degree white light, but the rules don't say anything about that. There may be some official interpretation that allows for a single 360 degree light, but I don't see it in the rules. If it is there, please point it out.Please. ;^) Any one of these are good for a vessel under 12m, the case I mentioned is number (d) (1) in your list. When I got my ICC certification last month, I have to learn more about this then I ever wanted to know!
From your quoted rule: ;^)Jack, that's just not my reading of the rules. Masthead (225 degrees) forward, stern light aft (135 degrees), see Rule 21 Definitions. Functionally, the two lights form a 360 degree white light, but the rules don't say anything about that. There may be some official interpretation that allows for a single 360 degree light, but I don't see it in the rules. If it is there, please point it out.
Beginning to feel like Gibbs from NCIS, and rule 23 is.....
