Hoping you may be able to help resolve this as putting it together 17 years ago is much easier than taking it apart today! I’ve apparently cracked the freshwater holding tank on our 1999 Hunter 310 on last hard sail. It is located under the vberth. I have removed all decking screws on the topside and all joiner screws underneath, but the decking still cannot be removed to access tank underneath. I suspect that when built in 1999 the manufacturer glued the decking to the joiner pieces between the vberth decking pieces? If you have any manufacturing records or means to validate how to remove that decking above the fresh water tank it would be most appreciated. Otherwise next step is the saw! Thanks, Tim
