Miracle light
Nov 26, 2008
1,970
Endeavour 42 Cruisin
I just installed an LED foredeck light and it MAKES POWER! Yes, it is making electricity! My Victron monitor says so. Turning the light on and the amp draw drops .25 amps. Light off and the amp draw goes up .25 amps. It makes .25 amps!
The miracle light!
EV21
Apr 29, 2016
94
Macgregor 21 Venture Delaware ...
And maybe get some sun bunnies to come aboard for tanning sessions.
Jan 4, 2006
7,806
I know you're hanging on to this idea like dear life itself :wink: ................... but have you tried this test with everything OFF except the foredeck light. I want to know if you show +0.25A on your Victron when you turn the light ON.
JamesG161
Feb 14, 2014
8,105
Hunter 430 Waveland, MS
We have the solution to the future energy needs!:clap:
It must have a "cold fusion" nuclear reactor inside.
Jim...
walt
Jun 1, 2007
3,556
will it be safe to use without a controller?
capta
Jun 4, 2009
5,101
That's why it's called electrickery on a boat.
Nov 8, 2010
11,386
The ground of the new light is wired upstream of the shunt??
Likes: BudGates
Nov 26, 2008
1,970
I dont think so.
I vaguely recall being able to check amp draw of the old bulb via the victron.
If its on the wrong side of the shunt, I suspect it it would not show up at all.
Nov 8, 2010
11,386
That would be the first thing to check. If the old bulb (I had guessed this was a fresh install) behaves as expected and the new one does not, then the plot clearly deepens.
