Yep, that is the low profile box I used last year. It overall worked just fine. The boat will go in a slip mostly day sailed so the anchor only gets used a handful of times during the season. With the locker, everything will be easy to get at but I wont have all that junk on the deck. I like having both the anchor and rode quickly available "just in case". This is a habit from sailing this boat at a high mountain lake. When a quick storm would come through I would just drop the anchor and wait out the storm instead of trying to compete with about a million power boats for the boat ramp.
Russ.. I will read that shortly. I want the box to have a little more room than dictated by just dropping it thought the hole so at the moment that is not an option. Im thinking I can assemble it inside that area and use AL angle screwed to the wood plus epoxy to hold it together. Then water proof it with glass cloth and epoxy. I want to put the "hooks" in for a drain but may worry about that later (boat lives in the desert - not much rain).
I had to think about cutting that hole for a while as there isnt any going back. But so far I am not regretting anything.
