I suppose so. So?wouldn't I have to cut access holes in the roof of the cabin to install the backing plates and nuts, as the cabin roof and deck are separated with a gap?
Cutting holes in one's boat is intimidating, I know, so we tend to over-analyze the heck out of their placement. Nothing wrong with that. But all that trepidation goes away when the bit finally digs in.just hoping there might be access without cutting holes in the boat...
What does that even mean? A good backing plate should suffice....the scale of docking...
But to use as a preventer, I can't imagine loads exceeding much over 100 lbs.Hey justsomeguy, it just meant that the stresses put on the thinner fiberglass required for holding the boat at dock, such as using spring lines, could rip the fiberglass...And someone had said it could be 800 poounds or something, so it sounded pretty hefty to me, like we were talking about some larger loads, and shock loads on top of that.
See post #35...But to use as a preventer, I can't imagine loads exceeding much over 100 lbs.
"Someone" is overestimating?
See post #35...
I don't presume to know everything, so can't speak with authority to disregard such a comment. I was simply responding based on the input of others.
Perhaps you should provide support for your 100 lb supposition?
I do believe Mccneo is overestimating the possible loading on a properly set preventer. I appreciate your hesitation, but I think it's unwarranted.I have a 4:1 vang attached to a bail on the boom just forward of the sliding hatch cover. I attach a preventer to the same bail as the vang when I am close to dead downwind on a run. I used a lighter nylon parachute chord with a quick shackle for awhile until I realized the nylon chord wouldn't withstand the load if the main sail was caught by the lee in a stiff breeze. Main sheet block loading for a mid-boom main-sheet bail can reach nearly 800 lbs loading in a 20 knot breeze. It will take a reasonable size line for a preventer to any good and not break. I now use 3/8 braid on braid but only as a single line - not a 4:1.
Keep in mind that the most significant injuries on a sailboat come from being hit by the uncontrolled boom. Use of a preventer is pretty cheap insurance against a serious injury.
LOL...I've done this, and I know what you're talking about...vis, if you're applying engineering theory to a 26, I'd offer that you stick your head in the cavity under the front berth and look out either side. If you can't see daylight shining through the glass, you're lucky. The good news in the cleat commentary is that while backing plates are going to help, the boat isn't so heavy that the loads on a cleat at the center's spring line would ever likely damage the boat.
I dunno... How much load IS there on the midpoint of the boom, going DW with a sail full of wind, and the wind suddenly switches to the other side? What shock loads are created? It's enough to knock a person out, or over the side... But I don't know the numbers.This estimate seems to apply to an upwind load, and added shock. As a preventer, used for downwind sailing, the cleat would be subject to much less loading, no? I do appreciate your hesitation, but I think it's unwarranted.
Yah, I've edited my post to reflect that Mccneo was talking about DW stresses, but how far is your boom going to travel, creating shock loading, on an unintended jibe, when it's "prevented"?I dunno... How much load IS there on the midpoint of the boom, going DW with a sail full of wind, and the wind suddenly switches to the other side? What shock loads are created? It's enough to knock a person out, or over the side... But I don't know the numbers.
You, too?I'm not getting paid to do this or anything.![]()
	A preventer on each side is easy to rig so that they are out of the way except when in use and since you have the boat in a slip you don't need to be rigging them all the time. Glad you didn't go overboard but I'll bet the water there is still quite warm,....So.. looks like I need a preventer now as we tend to do a fair amount of wing on wing downwind sailing...
From your discription it sounds like your preventer is attached on the combing by the cockpit. If you move the attachment forward this effect becomes less. A classic preventer is attached to the boat near the bow. Once tensioned it will not allow the boom to swing any significant ammount at all.Something interesting about preventers.. Some preventers attach to the boom near the vang (or actually use the vang) and some attach near the mid boom sheeting location. When the main sail in extended out for down wind, the farther out you have the attachment to the boom, the farther IN the boom will swing before the preventer kicks in and limits things. Easy to imagine as one end of the preventer (however its implemented) must attach to the boat and if the other end is on the boom and the attachment point is way out to the side over the water, the boom can swing to an equal position the other way before the preventer tightens. So to get a small swing, you have to attach the preventer on the boom closer to the mast.
