Whats up with my interior bulbs?
Sep 19, 2016
123
Catalina 30 Port Sanilac
I bought some LED replacement bulbs and they wont turn on. I put the incandescent back in and they fire right up...what am I missing?
1992 Catalina
SFS
Aug 18, 2015
2,089
Currently Boatless Okinawa
Might be a polarity issue. Make sure positive (+) goes to positive and negative (-) goes to negative.
Also, are you sure you have the right replacements? Did you take the old bulbs in to compare when you bought the new ones?
Sep 19, 2016
123
Hmmm how would I address that? I am not much of an electrician.
Strange that the incandescent work but not the LED...or maybe its not strange at all.
Jun 19, 2004
365
Island Packet IP 32 99 Forked River, NJ
Easiest way to determine polarity is with a voltmeter. incandescent bulbs don't care about it; LED's do.
SFS
Aug 18, 2015
2,089
You can check polarity with a multi-meter, or a quicker method (if the bulbs allow for it) is to put the bulb in reversed, with respect to the connection points.
It's not likely a shore power issue, much more likely the bulbs are polarity dependent.
Nov 18, 2010
2,441
Catalina 310 Hingham, MA
Freeheelbillie,
Listen to the advice about the polarity. Get a multimeter and learn to use it. It will save you hours of frustration on your boat and probably thousands of dollars. There are plenty of YouTube videos on how to use it.
Good luck,
Jesse
Feb 20, 2011
8,062
Odd that a screw-in base would suffer from polarity issues.
As mentioned earlier, a check-up with a good multimeter should tell you where in the base the positive and negative terminals reside. Power up and carefully apply one of the probes to the threaded part and the other to the center contact of the socket. Note whether your voltage value is a negative or positive number. If it's positive, your probes are hooked up correctly.
Edit- We're talking about 12 volt bulbs, are we not?
Could that be related to a shore power issue?
WADR, you are NOT listening. :)
Check the polarity. If the new LEDs need the + and - switched, then just change the wires to the fixture.
It's DC NOT AC and had absolutely nothing to do with shorepower.
Do you have a multimeter?
Sep 19, 2016
123
I have one, I'll check polarity tomorrow. I think its a bulb issue (120v) need to check that too...picked them up at Walmart so almost certainly are 120v and not 12vDC.
Silly question from a sailboat electrical system newbie, shouldn't a 120v bulb work on shore power?
Catalina 320 Dana Point
When your Catalina was built ALL lights were 12 volts, mostly the "bayonet" mounts with pins that insert with a quarter turn, don't know where your screw in bulb came from but not the factory.
120 volt lights only work with shorepower or inverter, 12 volt works anywhere, any time.
I don't know what you have, this thread is a little confused, 12 volts can sting but 120 can kill.
