My 1980 36' Cherubini Hunter has been sailing for 36 years with snap shackle blocks on the aluminum toe rail for jib sheeting. Time for an upgrade ... and hopefully a few more degrees of close-haul pointing performance. Given the following, would like suggestions/impressions:
- On my main deck, just a few inches away from the cabin top, I will be installing a T-track for low lead jib-sheet cars: http://garhauermarine.com/images/product/LLC 2.jpg
- My deck construction is a sandwich of 1/4" FRP top layer + 1/2 -5/8"" plywood core + 1/4" FRP bottom layer.
- I am fully prepared to drill through all the layers and properly install the 5/16" bolts secured with washers and nuts from underneath.
- But this will entail cutting through the interior liner (or drilling out say 1" holes for each bolt) to gain access for securing and tightening the nuts. Afterwards, I will need to cover the scars with some sort of decorative piece(s) to "make it all pretty" again. A bit of a chore.
My question is: Any way to secure the T-track from the top only? I am thinking (but not confidently) something like drilling 5/8" diameter holes through the top FRP layer and the plywood core, but not through the bottom FRP layer. Then fill the hole with West System epoxy. Then secure the T-track only with 5/16" screws. Or even "tap" the hard epoxy so as to thread it for coarse thread 1" long SS bolts.
Another question. Is this a good application for Maine Sail's butyl tape product? I have used it for smaller installations were it is possible to ensure the butyl is wrapped around the screw/bolt and around the hole so the butyl gets well "squezed" into the beveled hole on the deck. But visualizing a t-track installation, a good butyl seal might be more difficult to achieve for each hole. In which case maybe standard marine caulk might be preferred?
Many thanks.
Many thanks.
