Advice on cutting a hole here?
JosefR
Sep 18, 2016
127
Catalina 30 Gulfport, Mississippi
http://forums.sailboatowners.com/index.php?threads/holding-tank-vent-clogged.181515/#post-1326136
In the above thread, I decided to drill a hole in my 89 Catalina 30TR for venting the holding tank as it is clogged somewhere. I AM LOOKING FOR THE C30 OWNERS WHO HAVE DONE THIS ALREADY.
Anyone with specific knowledge on how I cut this hole, or if it is OK to cut a hole in this location?
http://i43.photobucket.com/albums/e375/madwand1/20160909_102114_zpsqdqwpp1m.jpg
I would like to place the thru Hull fitting in the top right corner of this cabinet.
840
Catalina 30 Stillhouse Hollow Marina
I would not create a new hole. Fix the clog. It vents up through the lifeline stanchion just above the toilet. Can't take much to clear it.
JosefR
Sep 18, 2016
127
Thanks, but I asked about adding a vent, not tearing my boat apart to get to a microscopic hole and a tube I can't access. I explained this.
Likes: SFS
KD3PC
1,069
boatless rainbow Callao, VA
usually the vent holes are nearer to the water line...as the vent will "vent" pretty stinky stuff and the closer to the toe rail the more apparent that vent process will be to those aboard. You are wanting to minimize the rising odor...being beyond the hour glass of the hull, should allow the odor to sink, as opposed to being in the windstream to the topside.
Other than that...small hole saw, nothing in the way and some epoxy to seal the cut and a new fitting, with appropriate hose/vent line should do the deed.
Your boat,
Jun 9, 2004
615
Catalina 385 Marquette. Mi
Peggy recommends a clam shell thru hull....which my 385 has. Not a fan of the stantion vent. Call Catalina and ask about your proposed hole location. They're customer service is second to none. I reiterate. ..second to none.
Likes: JosefR
Dec 2, 1997
8,986
- - LIttle Rock
If you put a vent thru-hull near the waterline on sailboat, it will be underwater when the boat heels, forcing water into the tank that can overflow into the toilet discharge line and overflow the toilet. As for your theory of holding tank odor... it's created by anaerobic conditions in the tank...anaerobic gasses are heavier than air...they don't rise.
There have been many discussions on sbo.com about holding tank odor and how to ELIMINATE it by preventing it (yes, odor out the vent CAN be prevented!)...you might want to spend some time searching the archives for them 'cuz although you've been a member for eight years, it doesn't appear from your posts that you've ever read any of them! Best place to start is with the Plumbing and Sanitation forum and the Ask All Sailors forum.
Several weeks ago a Catalina owner posted how he installed a vent thru-hull and relocated his holding tank vent line from the stanchion to it. He included photos...but I haven't been able to find the thread and I can't remember who it was. So if you're out there, please show yourself and help Josef get it right!
druid
Apr 22, 2009
837
Ontario 32 Pender Harbour
I'm with Peggy on this one! In fact, as long as you're messing around with vents, put TWO in, one on either side of the bow. 1" minumum hose. You'll be amazed at the difference.
druid
Jul 14, 2015
840
Dumb idea. That is a reply to your topic header. But it is your boat.
JosefR
Sep 18, 2016
127
You might have some credibility if you were to explain why it's a dumb idea, but when someone who knows what they're talking about on the subject has already given her opinion on it and been backed up by many people, it just makes you look ill informed.
Jul 14, 2015
840
Because you will take on water if you sail at all in heavy air. I'm not worried about your opinions of me. You asked for opinions of your idea and I gave mine. Opinions are just that. Don't want them, don't ask for them.
JosefR
Sep 18, 2016
127
Actually, I did not ask for opinions. It'd be really helpful, in the future, if you'd take the time to read posts that you reply to. Thanks anyway.
Jul 14, 2015
840
Oh I get it now. Yeah, great idea.you are right, go for it. I only wish I had thought of it first. I may try it myself.
Bob S
Sep 27, 2007
1,808
Beneteau 393 New Bedford, MA
I used a hole saw. I did this a few years ago. I used the bolts holding the deck to the hull and a chainplate as a location guide. Measured 10 times :) and cut the hole to fit the fitting. I used 1" hose and a Uniseal per Peggie's instructions. I went almost straight up which isn't the best scenario but It has worked well. We almost never have issues with smells anymore.I put the hole exactly where you reference. I didn't use a clam shell as I would really have to bury the rail which I try avoiding at all costs.
Likes: JosefR
JosefR
Sep 18, 2016
127
Thanks Bob! Pretty straightforward, just drill a hole...
(use an open "bulkhead" thru-hull fitting, NOT a "vent" thru-hull)
The guy I talked to at Catalina was adamant to use a vent thru hull and Peggie says adamantly not to. I really don't see the difference, other than cosmetic. Neither will prevent water from entering, so why does Catalina insist on this? I couldn't get a satisfactory answer from the guy...
Jul 7, 2004
8,497
Hunter 30T Cheney, KS
I could see a clam shell over the fuel tank vent to help keep water out of the fuel ( have an inline dryer), or on the fresh water vent to keep soapy or other dirty water out. But I don't guess I see how it is preferred over a thru hull for the holding tank. What are you trying to keep out? To me it's in the same category as the bilge or shower discharge holes. Just my $.02. I'm open to a good explanation.
JosefR
Sep 18, 2016
127
I don't see how a clamshell is gonna keep anything out anyway. If there is no valve, it's the same as wide open. Seems like just added expense for nothing.
JosefR
Sep 18, 2016
127
Okay, I just got off the phone with Jerry Douglas, an engineer for Catalina in Florida. He says that I am going to be cutting through the hull liner as well as fiberglass, and that means there will be an air space in the hole that I cut. This means that possibly water could get inside so I need to be sure that either my fitting is sealed well or that I fill the inside of the hole.
As far as the clamshell, he said that is what they recommend, but he couldn't explain why it's any better than an open fitting. He said it wouldn't matter.
So I will be buying my fitting and my hose from West Marine in Biloxi. Is there a recommended marine sealing material that I can get while I'm there?
Jul 12, 2011
1,165
Leopard 40 Jupiter, Florida
To clarify Bob, you drilled from the outside in, so that fraying at the end of your hole is inside the boat. Right?
Jul 12, 2011
1,165
It also looks like you sealed yours with butyl tape, following Mainesail's advice.
