Heat exchanger bracket
Sep 3, 2012
29
Catalina 310 Marina del Rey, CA
The bracket on my Catalina 310 M25 XBP universal broke off. How do I replace it?
Thanks
Sep 29, 2008
1,981
Catalina 310 #185 Quantico
Or just get some strap from a plumbing supply, wrap it around the HX, mark for holes, drill the holes and bolt it to your engine.
Feb 20, 2013
52
Catalina 310 Channel Islands Harbor
Cloyd,
Fix it right, get the brackets from Mr. Cool. I have over 100 hours on the engine since installation and they work great. Yes they are expensive, but worth it. Don't know if you remember, I met you in Simi Valley awhile ago. Good luck with your project and let us know how it works out for you.
Jeff
Sep 3, 2012
29
Cloyd,
Jeff
Thanks. How did the installation go looks like a bear to get to? Must the hoses on the heat exchanger need to be removed other items need to be removed? Cloyd
Feb 20, 2013
52
Not easy, but can be done with out removing hoses. The bracket slides under the big bolts on the back of the engine. The clamps can be completely opened to go over the heat exchanger. Then put them together.
Sep 3, 2012
29
Thanks picture great help. I'll order brackets and give it a go.
DaveJ
Apr 2, 2013
528
I stole this picture from someone else's post a couple of years ago....
I used these brackets when I replaced my HX. They are a Universal item and cost about $12 at the time. The only issue I had installing them was they are very stiff and due to space issues, I couldn't squeeze them together close enough to use the short bolts that mount the HX. So I used ty-wraps to hold them together, started the bolts in the hole then cut and removed the ty-wraps. Not an easy job. Sorry, I don't have a part #. :(
While I was replacing the HX I replaced all the associated hoses as well. At any chafing points, there are lots with the vibration of this engine, I cut short pieces of rubber hose and used these to cover the engine cooling hoses. No issues since.
I don't have experience with the brackets mentioned above, but these worked great.
Cheers
Sep 3, 2012
29
Cheers
Thanks for help. The hoses for chaffing is a great idea.
