Hunter 326 owners: hot water heater question
Aug 9, 2016
4
Hunter 326 Oakland
Hi, I recently purchased a 2002 Hunter 326 which had its hot water heater removed before purchase, and I decided to install a new one. In the parts section of HunterOwners, the suggested model was a 13x13x19" unit, which I purchased, but which definitely does not fit!
If you own a Hunter 326 can you please advise me of the correct size, make or model of hot water heater in your boat, so that I can order and install the correct one?
Thanks in advance! Fair winds!
~ Grant
Aug 9, 2016
4
Hunter 326 Oakland
Thanks Ken I had already done that to no avail. Hoping someone with a 326 will reply with the dimensions I need.
Oct 29, 2005
2,363
I'll try take photos with the info this weekend. Hope the label is visible.
Aug 9, 2016
4
Hunter 326 Oakland
The water heater is a Force 10 water heater. I've attached the PDF of the owners manual and a picture of the label of the tank itself.
Thank you so much for the image and the PDF, that is extremely helpful! ~ Grant
